Rear Door Speaker Panels
Old Jun 9, 2005 | 08:09 AM
gsapatka's Avatar
I have a question about removing the rear speaker door panels to install new speakers. Do they come apart the same way that the front do, or do you have to remove the entire panel?
Old Jun 9, 2005 | 08:32 AM
rgod55's Avatar
You have to take off the whole door panel. If you need some instructions they exist. You'd have to do a search to find them, I don't remember where I found them last time.
Old Jun 9, 2005 | 10:00 AM
mikey88's Avatar
I just changed my speakers. The back door panel is held on by 3 screws. Two are located at the bottom of the door and one behind the inside door handle. You also have to remove the plastic part that goes up the back side of the window above the door lock. It just pops out. Take your time. Once you remove that lift the door panel upwards about 1-1.5 inches and it should come off. It's a good idea to have someone there to hold the door for you, because it will still be connected by wires and won't reach the ground to set it down. It's not too bad!!
Old Jun 9, 2005 | 11:19 AM
04fx4Scab's Avatar
unplug the harness for the power window switch.
Old Jun 9, 2005 | 11:24 AM
Skydiven4fun's Avatar
I was able to do mine in about 15 minutes each side, If you can't find the instructions anywhere, I can fax you a copy that I got from Crutchfield when I get in from offshore this monday, Also check Crutchfield advisor they may have it online, It's really a piece of cake.
