Removing rear door panels on 2005 s/c ???
I ran a search, but couldn't come up with anything on an '05 s/c. Just the front door panels... I installed speakers in the front yesterday, and now I'm thinking of dropping a set in the rear as well.... but I don't know how to remove the panels... on the front I just worked in the little hole from removing the grill & OEM speaker... made installing the crossovers a little challenging, but I was too chicken to try to pull the rest of the inner panel off!
I'm assuming it's the same as my 04; if so, there's a plastic plug in the door panel up near the top. Behind this plug is a bolt. Remove this bolt. Can't recall if theres any screws on the very bottom or not; if you can't see any, then there aren't. Aside from the bolt, and any screws that may or may not be on the very bottom, it's just trim clips.
ChrisAdams hopefully will check in; his memory is better about this stuff than mine is
I believe there are 6 screws/bolts to remove the rear panel...the one up top at the outer portion of the door under the plastic trim piece that pops off, two at the bottom, two behind the door handle trim piece and one under the window switch panel that pops off. There is a post here somewhere (can't remember specifics) that details the removal of the rear door panels....not hard - you just need to know where the bolts/fasteners are.
