AF-1 ----2 pipes?
AF-1 ----2 pipes?
I opened a box of AF-1 and inspected and everything is good...but what got me puzzled is that theres other (approx a foot lenght pipe) inside the AF1 chrome pipe ??? I can move it as slide in and out... whats it for ??
Thanks!
YOMAN!
Thanks!
YOMAN!
Thanks!
YOMAN!
Thanks!
YOMAN!
Uhh...
Can you remove that piece? I don't think it's supposed to be there... mine was one piece.
haha, if it sounds like what i think it is, af1 decided to "steal" aems design, losers.
AEM > AF1
Edit: It actually looks like a mold or something along those lines...
AEM > AF1
Heres Pictures:
http://pic6.picturetrail.com/VOL164/...6/98100188.jpg
http://pic6.picturetrail.com/VOL164/...6/98100150.jpg
You can see the 2 pipes, i can slide inward and outward but i cant get it out.
I will contact Mike troyer..oh well.
YOMAN!
YOMAN!
UPDATED:
Troyer said thats normal and thats how AF-1 design it so i went ahead and installed it.
WOW! its sweet and a bit add rumble i felt. I could feel it really suck air a lot hehe.
I could feel a bit more power now.
I floor it and damn its nice WOT! hehe!
No check engine light after 13 miles.
Didnt disconnect the battery.
YOMAN!
Superchip 87-Magnaflow SIDO- AF-1
YOMAN!
Heres Pictures:
YOMAN!
YOMAN!
I must have not paid enough attention to mine... *shrugs*
If I am not mistaken this was added to "clean up" the tube where the mass
air flow sensor per say seats. If you remember, on mine the hole was over sized in the tube itself and this was creating an effect on the air flow.
I am sure once Mike reads this that he will give a more definative answer.
Mine has the liner but it doesn't move! ... ?
I would have noticed movement as it got handeled a lot while carefully removing the matching ding on the filter side of the tube.
Anyway all seems to work just fine ... so far ...
Originally Posted by Marc Carpenter
Yours and mine does not have this sleeve RP.
Gotcha. I didn't think I would've missed this but, god knows I've missed bigger things in my life on more than one occasion...
So, what I'm hearing is that some have this and some don't? I'm assuming it's the 'newer' ones that have this?
RP
RP,
Mine has the inner "sleeve" also. I had to dremel one corner which was slightly protruding into the airflow sensor port. The sleeve goes from the throttle body end up to the beginning of the bend and is drilled out for the crankcase vent and the airflow sensor. Also UPS dinged both ends of my pipe and broke one of the nylon screws off. I straightened out the dings with my trusty ball pein hammer. Those UPS clowns could tear up an anvil with rubber mallet!
^if they packed it right, then it shouldn't have been damaged. Seems like AF1 is in a rush to get these out and is skimping on quality control (dented tubes, moveable sleeves, etc.). You shouldn't have to buy something (especially a $300 intake tube) and then have to take your dremel out to fix it.
For the details see the existing thread about Airforce one and the check engine light.
