AF-1 ----2 pipes?
Originally Posted by SteveVFX4
^if they packed it right, then it shouldn't have been damaged. Seems like AF1 is in a rush to get these out and is skimping on quality control (dented tubes, moveable sleeves, etc.). You shouldn't have to buy something (especially a $300 intake tube) and then have to take your dremel out to fix it.
I don’t know if I have an inner sleeve or not. I did have to use a small file to square out one corner of the hole for the MAS to make it fit. Then I pushed rags through the tube to clean out any particles but didn’t notice anything being loose inside. The AF1 has been on for two weeks; dozens of drive cycles, and so far no CEL.
