great idea for bug protection
Old May 26, 2005 | 06:06 AM
150cable's Avatar
Red face great idea for bug protection
but who is the person that mounted screen infront of the radiator and where can i perchase or how can i construct this can't figure out how to mount screen w/out tearing need info. thanks
Old May 26, 2005 | 10:11 AM
J-150's Avatar
are you asking or telling?
Old May 26, 2005 | 11:57 AM
mkinttrim's Avatar
I went to Lowe's and bought black pet screen(has a little larger holes and tougher). I just cut it out a cpl inches larger than radiator (actally a/c condenser) and zip strip it around the shroud. I also did this to oil cooler and tranny cooler. Works fine, had 90 degree heat here several times and no overheating so far!
Old May 26, 2005 | 12:05 PM
1969Mach's Avatar
There is a new composite screen material, and I can't remember the name, but it is about 70 percent thinner wire than standard nylon screen, and 50+ percent stronger. The stuff is nearly invisible from 5 feet away, and it allows much more airflow. Expensive, but worth it. You might look for it. I'm thinking it was at Lowes, but not sure.
Old May 26, 2005 | 02:04 PM
cndcowboy's Avatar
I used aluminum window screen from Canadian Tire, a hardware/auto store, like the others I just cut it to fit, and then zip tied it to the black part above the rad. You can't even see it from a few feet away.
Old May 27, 2005 | 12:05 PM
FrankLee's Avatar
I'm not sure what they're called, but I used 1/8" grid, 12" x 12" squares that you can get at craft stores. They come in several colors and are used for yarn weaving?
For my '98 Windstar, I bought three black squares and zip-tied them together with small black ties and cut to fit. They were strong, virtually invisible, worked great, and were still like new when I traded the van in last year.
Edit: I think it's called plastic canvas.
Old May 27, 2005 | 02:50 PM
jamzwayne's Avatar
Do a search on 3M clear bra and you get ---> THIS
Hope that helps.
Old Jun 2, 2005 | 11:35 PM
2005-Ford-KR's Avatar
Here's a good idea:
https://www.f150online.com/forums/sh...ght=bug+screen
I did something similar, but used 1/4" PVC pipe, cut it to desired length, bent it where I needed to, connected the ends together with couplers, and zip tied a fiberglass screen to it. Took less than 30 minutes to do. Fits nicely into cavity with no additional mounting hardware required.
