Can you Install Homelink Visor in 2005 F-150?
#33
I checked my wiring. The positive lead I spliced to the green wire with an orange stripe and the negative lead I spliced into the black wire furthest from the green/orange stiped wire. When I was installing mine I had used a volt meter to determine which wire had constant power.
#35
Thanks for the heads up on the wiring - I just purchased an 04 Lincoln LS Visor with HomeLink for $20.00 (e-bay) and will be installing it soon.....I really like the overhead console mounting location and may just go ahead and mount it there - but since I have the lighted vanity mirrors - I already have power & ground in the visor and can feel the outline of where the homelink would go in the visor....choices, choices
#36
#37
yeah, I got mine out of Ford Winstar visors and really had a tough time getting that darn Homelink out of there. The visor was pretty much trashed, and I also cracked apart my Homelink case as well. I need to glue it or tape it back together.
btw, I tried the wires as you said and they work fine (just stuck the homelink wires in the dome light plug as a test). I also put the homelink ground wire in the other black wires as well and it still worked. I will do my install on Saturday when I more time to play with.
