Snow Plow
Old May 18, 2005 | 08:25 PM
Swinn's Avatar
Snow Plow
Anyone have a plow on a 03 or 04? Did you do anything to the suspension or steering? What tires are you running and what plow manufacturer? How does it handle it. I have asked around on a plow site but I get "get a bigger truck".
Old May 18, 2005 | 10:24 PM
kingfish51's Avatar
From Ford, they state that the snow plow prep is only available on the 7700 lb payload package (2003, 2004 heritage model) or the heavy duty payload package (04 05 new model). I assume because they feel the front suspension will not hold up with the extar weight of the snow plow. I am sure someone has done it, but how successfully, I don't know.
Old May 18, 2005 | 10:27 PM
asinatra's Avatar
What do you plan to plow, sounds like you need a F250 because on the FSA
Old May 19, 2005 | 03:27 AM
inbred's Avatar
get a bigger truck...
the front ends are just not made for it. Unless you have the hd payload and plow prep package, put one on, and kiss most of your warranty byebye...
Old May 19, 2005 | 12:07 PM
2stroked's Avatar
If you're even medium serious about plowing, a 1/2 ton truck - ANY 1/2 ton truck - just isn't up to the job. I DRIVE and F-150. I PLOW with an F-350. The front end components (not to mention the drive train) just aren't up to the additional load and strain.
Old May 19, 2005 | 12:26 PM
jward's Avatar
One other suggestion, move to a warmer climate.
