Ghosts in the Machine
Old May 18, 2005 | 02:54 PM
MrPhish's Avatar
I'll see what you all think of this one. Several weeks ago my truck (04 SuperKrew 4x4 Lariat) developed two problems. First the radio would not shut off when the door opened. When I went to look at the Message Center I got a Data Error message under the menu items for Auto Lamps and Power Delay. Took the truck into the dealer. The tech was puzzled for two days. Tried replacing a relay behind the rear seat. NO FIX. More head scratching for two more days. Tried a few PCM reboots. NO FIX. Finally replaced the entire instrument cluster after one week. FIXED.
A few days latter noticed the A/C was not turning on even though outside temp was 85+. Back to dealer. Diagnostic computer says on-board computer not receiving any signal to activate the A/C. More PCM re boots and replaced a computer module. NO FIX. They are now stumped and have contacted the Ford Hotline for help. What say the F150Forum Faithful?
Old May 18, 2005 | 03:55 PM
J-150's Avatar
you need a match and gallon of gasoline...
Old May 18, 2005 | 03:56 PM
dzervit's Avatar
I say they yank & replace the ETAC in the dash... makes sense since the PCM said it never got the signal to turn it on.. .and since the PCM was replaced, then the ETAC should be next...
Old May 20, 2005 | 05:49 AM
MrPhish's Avatar
Exorcism Complete
For Information only (if it happens to you):
Problem turned out to be a corroded wire splice connected to the Body Control Module. Once splice was repaired, problem fixed. If goofy things happen ... consider body control module.
P.S. I didn't need the gasoline after all.
Old May 20, 2005 | 08:09 AM
kd4crs's Avatar
Where is the body control module located?
Old May 20, 2005 | 08:14 AM
MrPhish's Avatar
BCM Location
The dealer work order indicates the rear seat is removed to access the BCM. From speaking with the service tech, I believe it's the back of the rear seat up against the cab wall that is removed.
