bed bolts--To spray or not to spray?
Old May 7, 2005 | 11:06 AM
mattadams's Avatar
yes, definately take them out beforehand... when my truck was rhino lined (worse bedliner ever, FYI) they sprayed over the bolts, and when I had to take off the bed for soem body work, is was a major ordel to get to the bolts. Pain in the ***!
Old May 7, 2005 | 11:48 AM
Quintin's Avatar
Originally posted by phenom
aren't truck beds big and cumbersome, too?
And for the DIYer at home, or you, specifically, do you consider it a good time to jack up the bed instead?
6 bolts, two guys on the driver's side and a 2x4. Or, jack the truck up if necessary, crawl around on your back, take off the straps, evap lines, and fuel lines, balance it with a floor jack or see how much you can really bench... You decide.
I get your point, but I don't agree with it in the least. Fuel pumps and senders are replaced by dropping the tank, with the exeption of some imports, that's why there are only a couple straps that hold it up.
God forbid someone tries a different way to do the job. You say potato, I say potatoe...it's all a means to an end I suppose.
Old May 7, 2005 | 12:17 PM
Taking the bolts out and then spraying the liner makes the finished job look much more professional!
It makes it look like the guy who did it actually gave enough of a rip to take the extra time to remove the bolts and do it right!
Old May 7, 2005 | 03:21 PM
MPBTim's Avatar
Its ok to be different......My mama says "Dont knock it til you try it".
Old May 7, 2005 | 06:56 PM
jimmy k's Avatar
Like I said, too late for me. But I'll deal with it if the time ever comes.
mattadams, why do you think Rhino is the worst liner ever?I just got it done and see no problems with it. I might have gone with Line X, but they don't seem to have a dealer in the entire (most densely populated) state of NJ.
At any rate, had I known I would have asked that they not be sprayed. Maybe they could simply tape them off?
Old May 7, 2005 | 07:10 PM
RockyJSquirrel's Avatar
How many people here have ever removed/ reinstalled a truck bed, and was there some purpose for doing so? I pulled a bed off my '71 F100 after getting sideswiped, then installed a bed I bought from a junkyard. But that was 20 years ago and a spray-in bedliner would have been irrevelent. I've also pulled gas tanks a couple times to change out sending units and I always accessed them from the bottom. Never considered pulling the bed.
To those who are fretting over their bed bolts being sprayed: All I got to say is if this is your biggest problem then you are doing GREAT! Don't sweat it and worry about bed bolts if and when the day comes that you need to remove your bed for some unforseen reason.
Old May 7, 2005 | 08:53 PM
phenom's Avatar
bench press? What happened to your buddy that was helping you with the bed? Is he leaning against the garage door watchin' the game, drinkin' a Bud?
Old May 7, 2005 | 09:26 PM
Quintin's Avatar
Somehow, I get the feeling you've never done this before, so we'll leave it at that.
Old May 7, 2005 | 10:57 PM
Tbird69's Avatar
Agreed. I just find it better to drop the tank to do what still amounts to a pretty miserable job.
Old May 7, 2005 | 11:01 PM
Quintin's Avatar
Miserable is right. Get soaked in fuel a few times from head to toe, and it sours your desire to service a sender from below.
Old May 7, 2005 | 11:05 PM
Tbird69's Avatar
All right Quintin, I get it. Let it go!
Old May 7, 2005 | 11:34 PM
Quintin's Avatar
Didn't we have a disseration like this about gauges? Pfft, you're right, I'm right, we're all right, we'll leave it at that.
Old May 8, 2005 | 06:23 AM
MPBTim's Avatar
Im glad we can all get along.......Now lets hug........
Old May 8, 2005 | 10:32 AM
phenom's Avatar
I haven't, but I'd agree that TWO guys lifting the bed would be easier than ONE guy playing with the gas tank.
Old May 8, 2005 | 10:53 AM
valkyrie63's Avatar
If my sender went out under warranty and I happened to have a full tank at the time, they'd play hell getting me to pay for draining the tank.
You come into my shop with a full tank of gas and want a lousy sending unit changed you get told to come back when it's 1/4 tank or less. You'll just have to suffer and use the odometer and guess at your mileage.
Fuel pump is another thing entirely. If it doesn't run it doesn't run.
Common sense, it's a good thing.
By the way, a smart tech uses the transmission jack to lower the fuel tank down.
