weird tire shake
Old Mar 24, 2005 | 01:42 AM
HHIFX4's Avatar
weird tire shake
have any of you guys experienced a weird shake or (hate to say it but) vibe when you frist take off or when you are turning at a low speed??? its almost like if you were on a gravel road and the rocks were slipping out underneath the tires. any thoughts?
Old Mar 24, 2005 | 09:13 AM
jztbcz's Avatar
It just sounds like your limited slip doing its thing, that's what my
rig does from time too time. (if you got the limited slip) I wouldn't
worry about it too much ( unless you don't have ls ) then in that
case you might need a little lubing.
Old Mar 24, 2005 | 10:22 AM
skingsley1's Avatar
I had the same problem with my truck and the Dealer changed out the clutch packs in the rear end and that solved the problem.
Old Mar 24, 2005 | 12:22 PM
HHIFX4's Avatar
thanx i will run that by my dealer when i go back, im sure he will be thrilled after giving me 4 new tires a tail light and a reflash!
