3rd Brake Light LEAK!!
Old Mar 18, 2005 | 09:39 PM
gmascellino's Avatar
I had to wait one day to pick up my new 05 screw because of water leak.
They replaced the gasket and steam cleaned the carpets. They didn't check under the rear seat armrest, it was soaked!!
Old Mar 21, 2005 | 09:06 PM
sanddog's Avatar
I called my dealer today about the 3rd brake light leak. He said to bring it in and leave it. Apparently they have to remove the rear window to fix the problem. This means they have to remove the shell and I don't want them futzing with that...
I'm guessing using the "D" seal like TysonG and Buck Henry used involves simply taking the light housing loose and replacing the seal without messing with the wiring. Right?!?!?
I believe I can do that from the sides of the truck without having to move the shell. Right?!?!?
Thanks,
Terry - '04 F150 Scab, 4x4, 5.4
Old Mar 21, 2005 | 09:19 PM
Quintin's Avatar
There should be no need to remove the rear glass, unless it's leaking. Normally, just the foam seal around the third brake light assembly rolls over and leaks.
Old Feb 24, 2012 | 05:55 PM
88rxn/a's Avatar
Originally Posted by TritonXLT
a lot of us had this 3rd brake light leak, myself included. theres a TSB on this..they replaced my entire rear light and gasket. Also the dealer steam cleaned my back steat and headliner from the water
sorry for bringing the dead back....
will/does all the dealers have to clean the seat and headliner if my 3rd brake is leaking? i hopped in my truck today to find my back seat and headliner SOAKED.
Old Feb 24, 2012 | 11:24 PM
monoxide's Avatar
holy old post batman. but my third brake light is leaking also.
Old Feb 24, 2012 | 11:31 PM
Optika1 illushu's Avatar
Is this problem related to the 04 and early 05s or all 04-08s? Just curious if i need to look and see if mine is fubar. No leaks but i dont want one either!
Old Feb 29, 2012 | 10:43 PM
Tildybra's Avatar
My 07grill leaked today went to a dealer they said I need to buy a new brake light for around $100 lol
Old Mar 1, 2012 | 10:13 AM
freddytran's Avatar
silicone and be done with lol
Old Mar 2, 2013 | 05:29 PM
Curtis2009's Avatar
$6 leak fix
My truck has been doing the same (2009 f-150), water through the passenger assist handle and the rear corners in the headliner. I talked to the guys at the dealership were we got the truck to see if they'd do anything nice for us. The fellow there told me that the water was most likely coming from the rear brake/cargo lamp , and the satellite receiver. They of course wanted me to make an appointment, call me cheap but I thought id try and fix it first.
What I did,
rear lamp
(7mm socket), removed it (was definitely a leak), let lamp dry out, cleaned surrounding area and applied silicone, reinstalled it and should be good.
if the washers on the screws are worn out maybe a dab of silicone to seal those as well.
satellite receiver,
Had to remove passenger assist handle and sun visor (7mm socket and Phillips screwdriver). this should be enough to access the bolt holding the receiver (10mm socket). remove completely (definitely a leak zone), clean the area and applied the silicone to seal around the wholes, then reattached the receiver, buttoned it back up and called it good.
once the silicone has had time to dry I will pour water on them to test them, I don't see how it wont. I will let you know if it doesn't.
Spent $6 on exterior-grade (uv resistant), clear silicone.
Maybe Ford should use a rubber gasket rather than foam. Hmm.
