Power Folding Mirror Install on F150
#46
Here is one I found when searching "ford express" a bunch of crap came up but this was included in the search.
Express Module
Here is a pic for anyone hunting in the junk yards....
By the way not saying anyone would do this but im sure they are pocket sized.
Express Module
#47
What is the difference with the 05 harness and the 04 harness i know the 04 is missing some wires and the mirror movement motor wires are switch but aside from that why cant we just add the wires? Are the connectors different all together or what?
Side note I contacted the vegas company and they gave me the same prices as my local dealer. You know the outrageous prices like 200 or something for 1 mirror.
#48
Tim sold me the drivers side mirror for $169.49 and the pass side mirror for $94.46
In addition to the power folding mirrors you need one pigtail for the plug into the drivers side mirror [Tim can get you this], one momentary contact dual pole switch, two Type D relays and a copy of the electrical schematic for 05 F150 Power fold mirrors.
#49
#51
I dont even know where the damn switch is located i looked in a king ranch with pfm and i didnt see it. But from what the instructions say and searching around the forums no you can't use the factory switch from an 05.
I did notice in the schematics though that there is a pfm module that has 5 wires and looks alot like those express down / up modules. Maybe if you have that module the switch will work ? I dont know.
And I still havent found a round mom/off/mom switch anywhere like bobs.
#52
The PFM switch in the KR is just the normal PM switch. You just have it pointing in the middle and pull straight back and both mirros come in. The switch in the Lariat and the KR are identical so I don't know why it wouldn't work to use the factory switch. Also another thing bsm's directions are missing, is how to wire the puddle lamps on the mirrors. These are things that I need to iron out before I start this project.
#53
Yea I saw the puddle lamps too and in the schematics I have it looks like you just run #8 to a source that is only hot when you turn the int lights on and cold when you turn them off. Im not home right now or i would check on an interior source to tap into. When I get home ill check it out if no one else has posted here.
#54
#55
Also, my passenger mirror seems to go faster than the drivers side. Does anyone know a way to synch the two? They both moved at the same speed after the install.
#57
I know that in the directions it says we need the pigtail but i trying to figure out why. Because the connector in the schematics i see looks identical to the 05. Just trying to clear some things up before i get into it and have a surprise.
#58
Thats what i was thinking it was for so why not just go to the junkyard and grab some connectors to stripped the pins out of them.
Side note anyone buy the pfm module that i see behind the driverside passenger in the back wall of the cab on the 05's and try the stock switch that way?
Just trying to get use of the factory switch if i can.
Has anyone used the ford express down modules with this mod?
I think i understand what someone earlier was saying but the pin 4 that is a sensing wire or check wire or whatever do you just hook it back to 1 or 2 or what? and does this replace the relays?
#59
#60
Originally posted by F150 Duke
I wonder if the dealership knows how to do this mod. Maybe we can try and leach info off them to do it ourselves. Will bsm's wiring scheme and installation even work for me since I have an 05?
