tire spin
Old Feb 27, 2005 | 03:05 PM
DHutch's Avatar
tire spin
Just a quick question. I have a 2004 reg. Cab. f-150 with the 4.6L with 3.55 non slip gearing. I can't spin the tires from a dead stop but, if i put it in reverse i can easily spin the tires with no problem. Why is that?
Old Feb 27, 2005 | 03:11 PM
DrPaul84's Avatar
cause the weight shift...
Old Feb 27, 2005 | 03:13 PM
04 RED LARIAT's Avatar
The rearend is lighter and when in reverse you are pulling the heavy front end so it will spin. But when going forward you are pushing all that heavy weight.
Old Feb 27, 2005 | 03:14 PM
DHutch's Avatar
Thanks Dr.Paul
I figured it was someting like that.
Old Feb 27, 2005 | 03:16 PM
DHutch's Avatar
Thanks Red Lariat
Old Feb 27, 2005 | 04:06 PM
BHibbs's Avatar
I think there is a Higher Reverse gear as well. Not sure what the ratio is....
Old Feb 27, 2005 | 04:08 PM
DHutch's Avatar
Thanks Red Lariat
Old Feb 27, 2005 | 06:42 PM
madtrucker's Avatar
does anyone know how fast you can go in reverse?
Old Feb 27, 2005 | 07:07 PM
madtrucker's Avatar
i had the same problem. i wanted to peel out by just flooring it. i went to the dealership and they reflashed the pcm. after that i could peel out at every stop. now that i have a k&N filter and an exhaust i cant peel out anymore from a stop. took away too much torque but i have a fast top end now. The other day it was raingin and i was going 60mph and i floored it and i lost traction i was so scared i started to fishtale a little and i almost crapped my pants. it was pretty cool though
Old Feb 27, 2005 | 07:23 PM
04SCREW98COBRA's Avatar
I do not have the answer to that but....
I must ask, why on earth would you want to know?
Old Feb 27, 2005 | 07:41 PM
madtrucker's Avatar
dont know. i was just curious. it kinda feels like the reverse is geared kind of high. I would like a more low gear for reverse
Old Feb 27, 2005 | 08:17 PM
jpdadeo's Avatar
Transmission: 4R75E 4-speed automatic with overdrive
Gear ratios
1st 2.84:1
2nd 1.55:1
3rd 1.00:1
4th 0.70:1
Reverse 2.33:1
