is this normal???
Old Feb 18, 2005 | 09:45 AM
1BadFX4's Avatar
is this normal???
when my truck is kinda cold, when i start it, it revs to almost 2500rpms, is this normal, it seems like it stays up there for a second or 2, but then it goes down to normal idle???
Old Feb 18, 2005 | 09:48 AM
YOMAN's Avatar
Seem to me its a bit high to me....when i started up my f150 in very cold weather, it went up to UNDER 1.5K-RPM then drop to 600 ish..
YOMAN!
Old Feb 18, 2005 | 10:07 AM
1BadFX4's Avatar
it seemed to be around or alittle above the 2,000rpm mark, 1st time it has done it was lastnight, and i had install my Superchips tuner yesterday moring, could it have anything to do with this???
Old Feb 18, 2005 | 10:21 AM
1BadFX4's Avatar
i just went outside and tried it this morning, and it went up to about 1800rpm i would say, and went down to about 1500 and stayed for a few seconds, and then back down to 600rpms.....
Old Feb 18, 2005 | 10:23 AM
Buck Henry's Avatar
That's just the modern electronic version of the automatic choke kicking in, isn't it?
Old Feb 18, 2005 | 10:24 AM
Arctic Cat F7's Avatar
Mine goes up to about 1300 or so RPM and after a couple of seconds comes down to 850-900 RPM.
Old Feb 18, 2005 | 10:45 AM
YOMAN's Avatar
I also installed Superchip program *87* and magnaflow SI/DO and the RPM does not change.
YOMAN!
Old Feb 18, 2005 | 11:43 AM
EddyG88's Avatar
I have the SCT as well and today it was 24 deg outside at 6am, and the truck initially revd to around 1500-2000 and within 3-5 seconds it was down to 1100 and then after about 10-20 seconds it was down to 600.
Old Feb 18, 2005 | 01:01 PM
myst's Avatar
Your truck is managing its emissions output. (Percentage wise anyway, I'm not so sure about total output... )
Old Feb 18, 2005 | 01:24 PM
04f150guy's Avatar
dont worry guys, ive asked the tech's at the local dealership and they said it is completely normal for the rpm's to rise like that on a cold start. im not sure why it does that, but i know that all 04-05 f150's do it. just be sure not to slip it in drive or reverse when the rpm's are that high...she'll take off on ya!
