30K maintenance
Hey guys,
I believe, as I know some of you do, in doing as much of my own maintenence that I can. I checked the "recommended maintence schedule" that came with our trucks and it looks like its time for the tranny fluid and fuel filter to be changed (among other things).
Has anyone done this yet?
I have not got a shop manual and the owners manual does not mention the fuel filter. Where is it located?
BTW, I usually do fuel filters myself and used to do tranny fluid changes on my old ranger but realized I couldn't replace or flush all the fluid from torque converter and such. I got a coupon in the mail for a $99 tranny fluid flush (regular price ~$140) from the dealer that I got my truck from which is about an hour away. The closest dealer is about 5 minutes away, but they say they can't honor the coupon. I might just have the fuel filter replaced by the dealer when they do the tranny fluid change.
I dont know how to do it but I remember some guys talking about the fuel filter being real easy to change. It is located on the inside of the frame, just about under the drivers side door. It also has some easy connector thing that makes it easier to replace.
You may also want to replace your cabin air filter (where ever that is).
Originally posted by MHK
Zoltan, Where did you get the dual exaust pipes?
Was Capital Ford the dealer that wouldn't honor the coupon?
THANKS, MH
THANKS, MH
Yeah, it was Capital Ford that would not honor the coupon. They said there was no way they could. Actually, they sounded like it was hard to believe that Dunn Benson would do it for so cheap. I got the truck from Dunn-Benson which is about an hour away from me.
Originally posted by dzervit
No, it doesn't. You still need a removal tool for both ends. jpdadeo had a good post describing his replacement procedure.
Many auto parts stores (like Auto Zone) have specialty loaner tools available and they do not charge you to borrow these tools. I would check with your local auto parts store before buying a tool you might use a handful of times over the life of the truck.
.............Don't tell me it's just on the Lariat.
Originally posted by fx4scab
My dealer's service dept. told me there wasn't a cabin filter in these trucks when I asked about it. Are they full of bunk or what?
EDIT: Then again, with the FX3½ I wouldn't be surprised if they didn't bother with filters of any kind..
JP said he got his at Sears for $10. It has other uses as well. And a filter under warrenty?! Yeah, right!
I'm not sure about the cabin filter. Looks like I need to pick up a real service manual.
I think I will just pick up one of those disconnect tool sets from sears, it's only $10 and has the potential for other uses.
where is the cabin filter located. i got one of those lariats and havent seen the filter. havent really torn the truck apart looking though.
zoltan--------thats not the beach at hatteras that you are parked on is it?
