got problem
Old Feb 17, 2005 | 11:48 AM
  #31
sacramentojoe's Avatar
Originally posted by Dr No
Triton.
The original code cannot be changed.You can add your code but the original code will still open the lock.I don't know if a ford dealer can change it with the computer reader.Ask them. If ford cannot change it you will need to replace the module.
Hope that helps.
Mike
Dealership told me the same thing when I inquired about it.
Old Feb 17, 2005 | 11:50 AM
  #32
ke7065's Avatar
Yeah, on my 04 I can remove any code someone else put in but not the factory code. Go figure...
Hope the guy I bought it from has a short memory.
Old Feb 17, 2005 | 01:16 PM
  #33
BREWDUDE's Avatar
Originally posted by dzervit
Triton, RTFM!!! It's in there! Really!
Wooo...back up johnny..put the gun down. Re-read his last post. He said he LOST the manual. LTFM
Someone getting upset with the boards lately
Old Feb 17, 2005 | 01:32 PM
  #34
dzervit's Avatar
Shoot first, ask questions later.
Old Feb 17, 2005 | 03:05 PM
  #35
TritonXLT's Avatar
Banned
Guys, before you kill each other, is there a way you can tell me to at least how to change the code since I lost the book? I have to buy another manual though now, I don't know who took it or where I placed it at.
Old Feb 18, 2005 | 10:38 AM
  #36
MRBIG's Avatar
You will need a factory code before you can program your personal code........time to go to the dealer
Old Feb 18, 2005 | 01:04 PM
  #37
Blues001's Avatar
Your Owners Manual
http://www.genuineflmservice.com/default.asp?page=E4
Old Feb 18, 2005 | 02:06 PM
  #38
thw420's Avatar
KEYLESS ENTRY SYSTEM (IF EQUIPPED)
You can use the keyless entry
keypad to:
• lock all vehicle doors.
• unlock only the driver’s door.
• unlock all vehicle doors.
• program/erase the customer keycode.
• enable/disable the autolocking feature.
The keypad can be operated with the factory set 5–digit entry code; this
code is located on the owner’s wallet card in the glove box, is marked on
the computer module, and is available from your authorized dealer. You
can also create your own 5–digit personal entry code.
When pressing the controls on the keypad, press the middle of the
controls to ensure a good activation.
Programming a personal entry code
To create your own personal entry code:
1. Enter the factory set code (keypad will illuminate when pressed).
2. Within five seconds press the 1 • 2 on the keypad.
3. Enter your personal 5-digit code. Each number must be entered
within five seconds of each other.
4. After the code is entered, the locks will cycle, confirming that the new
code has been set.
Tips:
• Do not set a code that uses five of the same number.
• Do not use five numbers in sequential order.
• The factory set code will work even if you have set your own personal
code.
• If you set a second personal code it will erase your first personal code.
Erasing personal code
1. Enter the factory set 5–digit code.
2. Press and release 1 • 2 then,
3. Press and hold the 1 • 2 for two seconds. This must be done within
five seconds of completing Step 1.
Old Feb 18, 2005 | 02:48 PM
  #39
TritonXLT's Avatar
Banned
thank you for the information!! I will give it a shot this afternoon!!
Old Feb 18, 2005 | 04:14 PM
  #40
jamzwayne's Avatar
HOLT *****
Took 3 pages for the dude to get a good answer.
I can understand the bashing due to his FIRST post. (that was great BTW)
