blocks in back
blocks in back
I got a 2" EZ lift leveling spacer on my front for my 2WD 04 f-150. I got sand in the back of my truck for the winter and it sits a bit lower in the back at times when I'm carrying a load. Can I get a block to put in the rear to bring it up, like the 4wd's have? If so, where can I buy the blocks? Thanks
You can buy the blocks, called spacers from Ford Parts, at your local dealers parts counter. They are around $40, but you need longer u-bolts and the nuts that go with it. The u-bolts are longer and different diameter than the ones you have now.
or
Make a plea for someone who purchased a lift kit and no longer needs their factory blocks.
Hope that helps
or
Hope that helps
