305/55/20 Terra Grapplers
Old 01-27-2005, 09:10 AM
CarlJ's Avatar
I am buying 20x9 rims with 30mm offset. I have no lift. Will the 305/55/20 fit without rubbing, or will I have to do the 305/50/20? I know the 50 doesn't rub on that wheel with no lift, because I have talked to people that have them, but I would like to do the 55. Will it work? My truck is a 2005 Supercrew 4x4.
By the way, I did do a search. In fact, I did many searches and still can't find an answer, so please help.
Old 01-27-2005, 03:56 PM
wandell's Avatar
That tire works out to be a 33x12.50-20. I think you are gonna need a leveling kit to fit them.
Old 01-27-2005, 04:06 PM
1BadFX4's Avatar
yeah, u will need a leveling kit, i was goin to do that wheel/tire package, but i decided on 17" with 33"S since tires are so expensive for 20"s and i just liked the beefier look of the 17"s cause theres more tire there...
BTW, go to Centerlinewheels.com and go to gallerys under trucks, and u can see a 4x4 F-150 with a leveling kit and that same tire setup...
Old 02-02-2005, 10:23 PM
CarlJ's Avatar
Which leveling kit do you guys suggest? I hear the autospring one is better than the daystar. Is this true?
Old 02-02-2005, 10:30 PM
wandell's Avatar
The only reason I'd say the Autospring lift is better is because it's a lot easier to install than the Daystar.
Old 02-03-2005, 01:10 PM
04SCREW98COBRA's Avatar
I have the 2 inch autospring and 305 55 20 Nitto TG's. No rubbing at all.
Old 02-03-2005, 04:47 PM
1BadFX4's Avatar
when u goin to post some pics man???
Old 02-03-2005, 05:13 PM
Old 02-03-2005, 05:16 PM
Old 02-03-2005, 05:50 PM
1BadFX4's Avatar
it looks good man, how much u have 2 give for the tires?? i was thinkin of doin that setup. but i think iam doin 17"s with 33"s cause the tires are way cheaper, and i would hate 2 keep some 20"s clean thru the winter.... looks awsome though man...
Old 02-03-2005, 06:09 PM
freekyFX4's Avatar
The cheapest I could find them in that size was $283 each at www.onlinetires.com
Old 02-03-2005, 07:12 PM
DrPaul84's Avatar
they are 260 @ discounttiredirect.... for 305/55/20 ....
Old 02-03-2005, 10:16 PM
wandell's Avatar
Nice!!
Old 02-04-2005, 01:23 AM
Thanks for the compliments guys!
I got the tires from a local place for $259 per tire. Expensive, but they look and drive amazing!
Old 02-07-2005, 05:03 PM
CarlJ's Avatar
04screw98cobra - Do you think those wheels and tires would have fit without the leveling kit?
Quick Reply: 305/55/20 Terra Grapplers
