tires
Old Jan 23, 2005 | 08:39 PM
Dp2boy's Avatar
tires
Does anyone know what the largest tire size is that will fit on the factory 17" aluminum wheel ??
Old Jan 23, 2005 | 08:53 PM
ke7065's Avatar
DP2,
Use the search function at the top right of the forum list. There has been a lot of discussion on the 17's and 18's-that's propbably why you're not getting any responses.
I am running 18's so I can't give you an answer. Good luck
Old Jan 23, 2005 | 08:57 PM
Dp2boy's Avatar
I've tried to do searches for 2 days now and evidently the search function is under repair. I just got my truck so of course I'm impatient and want to put bigger tires on it right away !
Old Jan 23, 2005 | 10:25 PM
dewyrussler's Avatar
I still have the stock General 255/70s on mine.
But most folks say you can go 285/70-17 very safely without lifting anything. The 17" wheels are 7.5" wide, so most tire manufacturers say 285 is the widest.
Some folks have put larger on with reportedly no problems except some rubbing...or they have installed autospring kits (or similar lifts) to make clearance.
Hope this helps until the search function is up and running again. Once it is, you should be able to find all the info you need.
Old Jan 23, 2005 | 10:39 PM
wandell's Avatar
Several people here and at FTW have run 315/70-17's (35x12.50) on the OEM wheels without any problems. A lot of people are running 35's on the 04-05 4x4's by using the OEM wheels and a 2.5 inch leveling kit.
Old Jan 23, 2005 | 10:52 PM
nitzer280's Avatar
As Wandell will attest, "it's all in the backspacing!!"
Old Jan 23, 2005 | 11:00 PM
wandell's Avatar
Amen, brother. It is critical on the new trucks.
Old Jan 23, 2005 | 11:01 PM
RockyJSquirrel's Avatar
This site has two different 'tire and wheel' forums and approx. 75% of the threads are "what's the biggest tire I can put on......".
Old Jan 24, 2005 | 08:03 AM
wandell's Avatar
Yep!
Old Jan 24, 2005 | 09:20 PM
madtrucker's Avatar
what are you going to do with the stock tires you take off?how many miles on them? i just might buy them
Old Jan 24, 2005 | 09:56 PM
Dp2boy's Avatar
still not sure of what I'm going to do. don't want to have to re-gear the rear end so if I go up in size it will probably be minimal. I'll post if I sell the current tires (125 miles right now).
Old Jan 25, 2005 | 02:16 PM
kirkb's Avatar
ke7065,
What kind and size are your tires?
I also want to keep the stock 18" FX4 wheels on my truck - but want to level it and put some tires on that are not too big - your's looks great.
Thanks,
Kirk
Old Jan 25, 2005 | 08:50 PM
ke7065's Avatar
Kirk,
325/60R18 LT Nitto Terra Grapplers. Can't give you a price, they were put on the truck by the dealer prior to my buying it. Decent ride, "Tonka Toy' look.
Rubs at full lock on lower a-arm in front and sway at back-again only at full lock. Good luck!
