racing idle at start up
Old Jan 19, 2005 | 02:47 PM
HHIFX4's Avatar
does any have a problem with there truck racing when they start it up?? it also will surge when i first start driving. so do yall think this is something that a reflash will fix?? whenever i bring this up to my dealer they alwayse give me the run around and act like they have never heard of a reflash.
Old Jan 19, 2005 | 02:53 PM
thw420's Avatar
Yeah, I believe they all do this. From what I've read in the past, it has something to do with CAFE. The engine warms up quicker and results in less emissions. blah blah blah....
Old Jan 19, 2005 | 04:35 PM
Stuka Dude's Avatar
Not sure what you have for an engine....... I've got the 4.6 and yeah, it does idle a bit high after start-up. It simmers down fairly quickly though. My brothers F-150 does the same along with my buddys Mustang. both with 4.6's.
Old Jan 19, 2005 | 05:23 PM
jpdadeo's Avatar
Mine idles high for 30 sec or so on a cold start and the colder the outside temp is the higher it seems to idle. I got a 5.4
Old Jan 19, 2005 | 05:28 PM
L Squared's Avatar
My 5.4 revs a little high on cold start-up but drops off pretty quickly. Every vehicle that I have ever had does this on cold start. It appears that the colder (to a point) it is the higher it revs. After it has warmed up the start revs are about normal.
Old Jan 19, 2005 | 07:19 PM
HHIFX4's Avatar
mine is a 5.4, what about it surging when i first take off
Old Jan 19, 2005 | 10:23 PM
Droog's Avatar
What rpm do you consider surging?
Unless it's real high it sounds just like a rich mixture to help warm up when cold. ( Like a choke on old engines )
Old Jan 19, 2005 | 10:25 PM
Droog's Avatar
What rpm do you racing at start up?
Old Jan 19, 2005 | 11:10 PM
Tbird69's Avatar
The engine runs at a higher RPM when started to allow the converters to warm up faster. On a -30C morning mine starts at about 1500 revs and then comes down to about 900-1000. It stays in this range for about 5-10 min. then slows to curb idle about 500 RPM.
As for the surging, go to your dealer and get the reflash done. My truck did the same thing, the reflash cured it.
Old Jan 19, 2005 | 11:19 PM
HHIFX4's Avatar
thanks guys im off to the stealership tomorrow to get it done
