Single 10" Sub Enclosures
Old Jan 17, 2005 | 03:58 AM
CrazyAssNick's Avatar
Thumbs down Single 10" Sub Enclosures
hey, i need to do something with my factory radio and am looking to install a single 10" sub. can you guys hook me up with some links to the various boxes made for an 05 Supercab. also some info in pulling and installing new door speakers. i got some pioneer 4 way 6x8's on the way. i want to run a 10" JL 10W3v2 and hopefully a 5 channel amp off my Eclipse av5132!
Old Jan 17, 2005 | 07:09 AM
jhartz's Avatar
www.theboxxman.com
Pro box... single 10" enclosure will fit a jl 10w3....
Old Jan 17, 2005 | 10:52 AM
04 Tan Scab's Avatar
Q-Logic - black box - fits great. See my gallery.
Old Jan 17, 2005 | 11:02 AM
Scubaman's Avatar
I put in an 8" bazooka. Fits like a glove. Dont even have to tie it down the seat does it and it matches the interior.
https://www.f150online.com/galleries...503-109924.jpg
Old Jan 17, 2005 | 12:19 PM
gordonzoo's Avatar
I also am in the middle of revamping. I have the single Disc stereo. Is there an easy way to remove the head unit without taking the dash apart. I saw a pair of din tools that will unlock the unit but I don't see the slots it fits into. I'm also replacing with 4 pioneer 3 ways 6x8" that I found on u-bid. I found a sub box on e-bay for 2x10" but they are only for 4-3/8" mounting depth but are .65cu/ft each. I will have to re-purchase subs to fit. I need more BOOM
Old Jan 17, 2005 | 02:13 PM
CAREFULLY unsnap the trim plate and there are four screws holding the factory unit in place. Couldn't be simpler and OMG what a ton of room in that cavity to work/ wire in once the gigantic factory unit is removed. By far the roomiest I've ever worked in.
Old Jan 17, 2005 | 07:42 PM
Greeny's Avatar
So far I've read about 3 options.
1. The Boxxman
2. QLogic
3. Bazzooka tube
Of the 3, which sounds best?
I just purchased a 2005 FX4 Supercab and I'm looking for a set-up myself. I had the JLAudio Stealthbox in my last truck and it sounded good, but pretty expensive. Looking for something that sounds just as good, but less expensive.
Old Jan 17, 2005 | 08:39 PM
zoo crew's Avatar
You can try this link too (I hope) http://www.supercrewsound.com/showprod2.asp?prodid=74
I was at an audio shop today looking at subs, boxes, & such. The old subs won't fit...too high of a profile. I almost ordered the box from this site, but the audio shop beat the price....
Heather
New baby 15 Jan 05------2005 Ford F-150 lariat 4wd
Old Jan 17, 2005 | 09:50 PM
hawk3254's Avatar
Account Suspended for Violation of *****s Rules
which q logic enclosure is that ??
thanks in advnace.....and also what sub do you have in there ?
Old Jan 17, 2005 | 10:20 PM
jhartz's Avatar
Probox is the s#@t!!! You can also fit a Rockford Fosgate Punch 10" which is 400w!!! Total for the box and sub is about $250..... Add an amp speakers, and hu and you got a pretty damn good system!!
Old Jan 17, 2005 | 10:25 PM
SteveVFX4's Avatar
I got the 10-inch supercrewsound.com box with a MTX sub and MTX 250-watt amp. I still have the factory cd player, and it still sounds pretty good. I mainly got it to fill out the music with some bass, but if I really crank it up, it can pound pretty hard.
Old Jan 18, 2005 | 12:17 AM
fujio001's Avatar
Try going to the website www.proboxrocks.com and find a dealer near you. The pictures really do not do the box justice. When I saw my first Probox, I was quite impressed. It is a very solid feeling MDF box with a very cool truckliner finish. Durable and probably has some additional sound dampening as well. I have seen very few boxes so well constructed.
Old Jan 19, 2005 | 04:42 PM
Lightbulb
does anyone have a box with more than a 5.75" mountng depth? that is exactly what my w3 is so im sure it wont fit correctly. anyone with experience?
Old Jan 19, 2005 | 05:31 PM
jhartz's Avatar
Just use a 1/4 or 5/8 spacer.... It will work!
Old Jan 19, 2005 | 05:32 PM
jhartz's Avatar
The probox will work with the supplied spacer... I think its 1/2"... and if that wont work, use a bigger spacer....
