taking off tails...
Old Jan 15, 2005 | 10:31 PM
DrPaul84's Avatar
taking off tails...
hows it done? tough? where do i get to the bolts from? i mgonna install the rest of my strobes tomorow...so would be good to know ahead of time! lemme know , thanks!
Old Jan 15, 2005 | 10:42 PM
inbred's Avatar
2 small hex head screws on the inside of your bed (for each side). One is right above the tailgate strap anchor, the other down towards the bottom of the bed. Obviously you'll have to open your tailgat to get to them.
Old Jan 15, 2005 | 10:43 PM
DrPaul84's Avatar
sounds easy! is their acess to the back of the tail lights from under the truck?? where are the wires coming from...so i know where i can run my cables an stuff....and thanks for the quick reply....
Old Jan 15, 2005 | 10:47 PM
Tbird69's Avatar
There are also two clips on the front edge of the light that hold it to the quarter panel. They are tight so be careful when removing or you will crack the lens.
Old Jan 15, 2005 | 10:49 PM
Tbird69's Avatar
There is no access from under the truck. You have to remove the light to get to the wires.
Old Jan 15, 2005 | 10:51 PM
inbred's Avatar
oops, forgot about those...it's been a long time since I had mine out.
You can easily get wires up there from right below them, I had mine off to run some wires behind them and came up from beneath them. May need a coathanger or fish line though unless you got some stiff wires to run.
edit:misread your last post--yes, you have to take the lights out to get to the wires. Once they're off, it's easy to bring new wires in from underneath..
Old Jan 15, 2005 | 10:53 PM
DrPaul84's Avatar
hrm last two posts contradict each other...can i get to the back of the tail light housing via under the truck body....i need to get cables up their for the strobes....
Old Jan 15, 2005 | 11:52 PM
PriorityOne's Avatar
Hey Dr, Remove the Bolts from the tails and they pop out real easy. FYI the reverse housing is tight in there, so if your going to be drilling there be carefull. My strobes are touching my reverse lights ever so slightly, so try to avoid this. Then run the cables to the front under the truck through any holes you can find to keep them out of the way. To get into the cab I went through a pre-existing hole I found under the passenger side floor molding. Good Luck!
Old Jan 15, 2005 | 11:54 PM
DrPaul84's Avatar
nah im gonna put em in the brake lights...i dunno actualyl lol, maybe ill do the reverse...who knows! ill decide tomorow lol
Old Jan 15, 2005 | 11:57 PM
inbred's Avatar
You can get cables up to the light from underneath the truck body, but you will have to remove the light to pull the wires up and connect your wiring.
Old Jan 16, 2005 | 09:36 AM
The reverse housings will be the brightest, if that's what you are seeking
Old Jan 16, 2005 | 09:39 AM
DrPaul84's Avatar
yea i know....i was checking it out last night cause i have a spare set of tails, where did you put the bulb in? like right next to the socket for the bulb? or was it possible to go from under, whats up with the bottom reflector thingy, it has its own lil housing too...
Old Jan 16, 2005 | 09:52 AM
Tbird69's Avatar
This is what I meant to say.
Old Jan 16, 2005 | 02:15 PM
It'd be kinda hard to drill from the lower housing into the middle (reverse) housing. Mine come in from the side.
Old Jan 17, 2005 | 12:32 AM
DrPaul84's Avatar
yup i did it ill be posting pics an video in a bit....thanks for the info
