vibration
Old Jan 13, 2005 | 05:04 PM
hawn2004's Avatar
Question vibration
has anyone with the vibration put on a dampening kit? Took it to the dealer to replace the u-joints, low and behold, the truck already had the new u-joints put on when they changed the driveshaft. Dealer says that Ford claims the dampener to be the fix. Is that really a fix or a mask. held offon ordering the kit because I am considering filing with the dsb. He says that if I don't let them try the dampening kit thart I will probably lose my case with the dsb. Any helpful advice would be greatfully appreciated.
Old Jan 14, 2005 | 06:01 AM
tjaas's Avatar
Registered User
I havn't heard of the dampening kit fixing any vibration.
You need to let the dealer do as much as he can to fix it, at least 4 trys in my opinion or tell you there is nothing more they can do before you submitt info to the DSB. They will help you it just take a lot of patients. It took me 10 months from my first visit to the dealer before my buy back through the DSB.
Old Jan 14, 2005 | 07:40 AM
Labrador's Avatar
The 30lb rubber disk dampening kit attached to the rear frame did nothing for my driveline vibration. I was told it was designed for the rebounce problem but it did not help that either. I called it Voodoo engineering and the service manager agreed.
