Skyjacker 3" kit is on
Old Jan 10, 2005 | 08:48 AM
SVTErick's Avatar
Skyjacker 3" lift kit is on
there are some problems. the upper a-arm angle is terribly bad. i think the spring may have to settle a bit before it gets ok, but its so low and near the coil. i was sent one defective u-bolt but i made due. here are some pics. took me 6 hours to install. the front was actually the hardest. the rear i had to flip the axle back to stock due to my drop kit. pics are in my gallery.
Old Jan 10, 2005 | 10:32 AM
ford2004F150's Avatar
THAT IS SICK! Very Very nice!
Can you still fit in the garage? How high is the cab?
Old Jan 10, 2005 | 11:13 AM
khendrix2374's Avatar
Nice man! I am waiting till I get some more money and Im gettin the 3" SkyJacker too. I have the a grey regular cab also, so now I know what mine will look like.... Couple of questions....
How does it handle off road? Does the upper control arm hit the springs on full extension? You can use the stock wheels right? I cant afford lift, tires, and wheels all at the same time.
Old Jan 10, 2005 | 01:19 PM
wandell's Avatar
Looks great!!
Old Jan 10, 2005 | 01:35 PM
dzervit's Avatar
Very hot. So how much did it actually lift the truck? Did you take any before/after shots or measure?
Old Jan 10, 2005 | 02:20 PM
minus_13's Avatar
Miami, FL? Nice! Where'd you have the work done?
Old Jan 10, 2005 | 04:18 PM
KaNigIt's Avatar
OMG... thats amazing! Thats exactly what I wish I could do to mine! How big are the tires? From the pics it looks like your not level?
Old Jan 10, 2005 | 07:15 PM
SVTErick's Avatar
i did the lift myself with a few friend over on FTW. the rear is actually a bit higher than the front which is fine. i like the raked look. its a bit of a mission to drive the truck now since the alignment is adjusted for a lowered application. im getting my alignment tommorow. the lift is a 3" lift out front and 2" out back. i dont have a garage so i wouldnt know and i havent taken any measurements, but its high as heck!
Old Jan 10, 2005 | 07:16 PM
Any potential problems up front with spring clearance?
Old Jan 10, 2005 | 07:27 PM
SVTErick's Avatar
i put a bunch of other pics in my gallery so check that out and let me know what you think one pic has the angle.
Old Jan 10, 2005 | 07:29 PM
poptop's Avatar
does that kit come with new knuckles and does it drop the front differential also new coilovers or just spacers
Old Jan 10, 2005 | 07:36 PM
SVTErick's Avatar
it brings new coils and shocks for the front and an add-a-leaf out back. i also bought skyjacker shocks for the rear. it doesnt bring any knuckles. i have a 2wd so i didnt have any big problems. although i had to re-flip the axle back into stock form.
Old Jan 10, 2005 | 09:47 PM
What kind of wheels/tires?
Old Jan 10, 2005 | 09:51 PM
SVTErick's Avatar
Eagle Alloy 187's 17x9 and Nitto Terra Grapplers 295/70/17
Old Jan 10, 2005 | 10:17 PM
HHIFX4's Avatar
great looking truck... hopefully i will be in the lifted club soon
does anyone know if skyjacker will break the lift apart by pieces?? all i need is the add a leaf and everyone i talk to says there is no part number for it. HELP!!
