Skyjacker 3" kit is on
Old Jan 10, 2005 | 11:00 PM
SVTErick's Avatar
you should call them they'll let you know what the deal is.
Old Jan 11, 2005 | 10:51 AM
easterisland's Avatar
Originally posted by HHIFX4
does anyone know if skyjacker will break the lift apart by pieces?? all i need is the add a leaf and everyone i talk to says there is no part number for it. HELP!!
My book says R3415 for rear add a leafs for 2wd and F432 for front scoils. The entire kit is F4321K.
For 4wd they don't list seperate parts.
For 4wd and 2wd 6" lifts the rear replacements springs are both the same part #FR45S.
Since the 6" rear springs assembly is the same on both 2wd and 4wd why wouldn't the add a leafs from the 2wd system work for the 4wd system?
Old Jan 11, 2005 | 10:57 AM
khendrix2374's Avatar
I thought on the 6" 4wd systems, they replaced the entire rear leaf springs...not just added a leaf or two
Old Jan 11, 2005 | 11:02 AM
Sounds like what I just said.
If the rear assembly is the same on 4wd and 2wd 6" lifts then why couldn't the add a leafs work on 2wd and 4wd's?
Old Jan 11, 2005 | 12:05 PM
SVTErick's Avatar
heres an update. i did my alignment today and the upper a-arm ball joint seems to have moved out quite a bit from the spring.
Old Jan 11, 2005 | 03:43 PM
wandell's Avatar
Old Jan 11, 2005 | 07:21 PM
poptop's Avatar
that angle does look radical although its hard to tell in a picture i imagine if skyjacker gets alot of complaints they'll come up with a new knuckle to solve any issues the truck looks awesome
Old Jan 11, 2005 | 07:28 PM
ThumperMX113's Avatar
How much did it cost you? and where did you buy from?
Old Jan 11, 2005 | 10:01 PM
SVTErick's Avatar
i bought it from www.4wheelcustoms.com talk to Chris Darnell. that dude has helped me out a lot. tell him Erick sent ya some business! i got the kit for around $650 shipped with new Skyjacker shocks out back which the kit does not come with.
