Reverse in 4X4
Old Jan 7, 2005 | 01:16 PM
2004Screw's Avatar
Reverse in 4X4
Hi Guys,
I am just wondering why my 04 can not go backwards (in reverse) when I am in 4x4 high? My 2001 was the same way.
Why is it designed like this?
Old Jan 7, 2005 | 01:24 PM
kirkb's Avatar
You certainly should be able to go in reverse - how else you going to get out of tight spots and being stuck.
Something is wrong if you cant get into reverse.
Kirk
Old Jan 7, 2005 | 01:26 PM
SilvrDrgn's Avatar
Are you trying to turn at the same time? Are you on a hard, dry surface? 4x4 should not be used on hard, dry surfaces.
Old Jan 7, 2005 | 01:29 PM
Arctic Cat F7's Avatar
I backed out of 3 1/2 feet of snow in 4 Low last weekend. I backed down a super steep hill at our hunting camp in 4 low.
There is something wrong with your truck. No joke. Take it in and have it looked at!! Your 4X4 system could be buggered. That would suck.
Old Jan 7, 2005 | 01:33 PM
easterisland's Avatar
Mine does 4wd hi and low in reverse. Do you have a Chevy?
Old Jan 7, 2005 | 01:58 PM
vvyk3d's Avatar
im with silvr and guessing the pavement was dry n he had the wheels turned, especially if his 01 was the same. Two trucks not going backwards is probably user error.
Old Jan 7, 2005 | 02:03 PM
2004Screw's Avatar
NO NOT A CHEVY - If i did have a chevy, I would not be asking on this site but rather a chevy one.
I have an 04 F-150 SCREW and no, It was not on dry pavement. I know a little more than not do do that. We currently have snow. I put it in revesre to back out of my driveway and it starts to move backwards but then it all tightens up and I stop.
I guess its off to the FIx it up place I go
Old Jan 7, 2005 | 02:43 PM
J-150's Avatar
yeah, have the dealer look at it... something just ain't right underneath the truck.
Old Jan 7, 2005 | 04:20 PM
04 RED LARIAT's Avatar
Whats the chances of one person having 2 trucks that done this?
Does it spin the rear wheels, or just lock up...Floor it and see what gives.
Old Jan 7, 2005 | 05:52 PM
Mike99a's Avatar
I had a former f150 that did a similiar thing, would not reverse in 4x4 and VERY stiff in 2wd but seemed to go in forward ok. The dealership found it was a frozen Emergency Brake cable, replaced it and was advised to not use the ebrake if I don't have to in freezing weather. just my .02 .
Old Jan 7, 2005 | 06:07 PM
2004Screw's Avatar
Thanks Mike99a.
I will mention it to the dealer when I take it in.
IThe dealership found it was a frozen Emergency Brake cable, replaced it and was advised to not use the ebrake if I don't have to in freezing weather.
BUILT FORD TOUGH!
Old Jan 7, 2005 | 07:33 PM
poptop's Avatar
mine stiffens up if i cut a hard turn but drives in 4x4 ok otherwise how sharp a turn can you make in 4x4 mode
Old Jan 7, 2005 | 10:08 PM
inbred's Avatar
did you have 4x4 engaged before you tried backing up? When you flip the switch for 4x4, you need some forward motion for it to lock in properly. If you're parked in your driveway in 2wd, flick the switch, and back up without going forward first, you will have engagement issues. One of the reasons I like cheap manual engagements...
