Test For Your F150
Originally Posted by myst
What I would like, if you all will humor me, is for someone to explain the following two things.
1) Under what conditions in a throttle-by-wire, automatic transmission, electronically controlled vehicle like ours, is the operator responsible for lugging the engine? Please give careful consideration in your augument as to why the drivetrain management system does not unlock the converter and/or downshift the transmission.
2) Under what conditions in a throttle-by-wire, electronic spark timing vehicle like ours should the engine management system deliver a fuel/air change that does not ignite? Please highlight how the vehicle operator is responsible for making this occur.
The owner's manual does highlight the use of the O/D lockout button for situations which cause the engine management system to hunt between gears. That is NOT the situation described in this thread.
Waiting for a well reasoned answer.
You have a problem with your truck, plain and simple. Take it to the dealer and let them fix it.
I can hold the pedal to the floor and still nothing, usually it takes me pumping the gas pedal 2-3 times before it will drop down a gear and take off
Well Im pretty sure that som-bitch is busted. Get it serviced before it leaves you stranded.
