Best place to attach tow rope?
If you get a hitch, slide the ball into the reciver upside down. So if your strap breaks the strap hopefully it will go under your truck and not into your tailgate or back window.
If you dont get a hitch tow hooks are the best. I would put a blanket over the stretched strap. If the strap breaks the blanket will absorb the recoil of the broken strap.
Okay. Heres the deal. Regardless of your trucks hardware you need a few basic items. First off get a good tow strap. I would reccomend ProComps 30,000lb 3"x30" strap from 4wheelparts. I just got mine yesterday and the quality is great. (You ALWAYS have to fear a failure during use so get good quality)
You also should pick up a couple of shackles, the same as shown in the pic above. 4wheelparts has a killer package with a tow receiver, a shackle receiver and a extra dring shackle.
I prefer dring shackles over hooks, and most offroad parks wont allow hooks anyway.
Now to do a recovery from the front of your truck, use your factory tow hooks. If you dont have any, buy a set (they are everywhere) and bolt them onto your frame with the proper hardware. From the rear of the truck you can do the same. If you have a hitch then buy the kit I mentioned above. I typically keep the D-Ring Shackle Receiver in all the time and always use it. It is the safest method of recovery.
A good thing to mention is you want to always do a recovery from the frame of a vehicle. Sure you can strap up to an axle or a bumper, but if its a good stuck, you can expect to cause some damage.
I thought ALL F150 2004/05 comes with front tow hooks ??
DO NOT GET TOW ROPE WITH METAL HOOKS cuz its waiting for to happen- can be a death or mess up injury!
Get 2" Shackle recvie w/ D-ring by Warn.com for rear hitch.
I used to own rock crawling Jeep wrangler (SOLD ) i had my friend to welded tow hook front and rear and it holds up well...be sure to do good job with welding and strong.
when to tow car/truck out of sand, snow or mud, be sure no one around near the tow strap like 20-30 or more feet away from it and dont stand around front or rear.
if tow strap break, its like you are shooting a rubber band it can happen so QUICK!!!
Zacky-
thats good idea, never thought of that .
YOMAN!
Zacky-
YOMAN!
A good thing to do when using a tow strap is to throw a jacket or something over the strap when taught. This way if the strap snaps, something will help deaded the force. And I cant stress enough to not skimp on recovery equipment.
4wheelparts has a great set of packages at a decent price, check them out....
http://www.4wheelparts.com/4wp/packa...ll.asp?cat=ACC
Heres the one I bought, along with a 30,000lbx30' strap
http://www.4wheelparts.com/4wp/packa...p?cat=TRUCKACC
Thanks for the help guys. I know to use the frame due a bad experience damaging my old explorer's axle. I am having trouble finding tow hooks, I guess I will have to go the stealership to see if I can find some front ones. For the back, do I have to get a hitch before attach any on the above mentioned items?
I assume when you say you cant find any you mean you cant find the stock tow loops. You can buy any tow hooks. Baja is right, they are everywhere.
For the back you can still go with hooks but you will have to mount them yourself. The hitch is a better option since you also gain the hitch.
