Basic Questions about Ford Gold Remote Start
I have seen questions posted on here a few times about the Ford Gold Remote start but I most of them were about installation and so on....but what I would like to know is if it works in conjunction with the factory keyless entry (do you have one remote or two with the kit), is it a dealer installed Ford item (is it covered by the 3yr/36000 warrenty, and what does it cost installed (on average)?
The Ford gold system comes with two 4 button remotes. It adds a siren under the hood along with the horn for the alarm part. It is covered 36/3 under your factory warranty, even if added after. It works flawlessly with the keyless system. Your price will vary, shop around, some people have paid between 300 to 900 to get it. Cost without install is around 290.00 for the alarm and pats bypass. Heres some of the features:
Remote start upto 500 ft away
Alarm for entry and shock (adjustable settings)
Turn on headlights if needed
Car finder (chirps progressively louder)
Can remove key once car is started and leave running
(nice for short trips into stores)
Remote runtime of 10 or 15 min.
Multiple settings in 5he setup menu
I posted a link in another post to the PDF file from ford on the alarm, if you scan over it, you can find all thats needed as far as info on the alarm in it.
Re: Basic Questions about Ford Gold Remote Start
The keypad will NOT set the gold alarm off when unlocking the doors with it. There is a 10 second delay to allow you to punch the right code in to unlock the doors. It will however go off if you keep punching random numbers on it. Thats how its designed, to let YOU in, and go off when someone else is fooling around trying to break in.
