Removing front door panels
Old Nov 11, 2004 | 09:15 PM
BigBlackTruck's Avatar
Arrow Removing front door panels
I cant find any discussions on removing the front door panels on a 2004. If any one has any tips or pictures, please post asap, as I am doing this right now.... thanks
Old Nov 11, 2004 | 09:23 PM
klassic's Avatar
Give me your email BigBlack, and I'll email you the removal instructions from the manual...
Old Nov 11, 2004 | 09:30 PM
Arrow
Ok, i figured out you dont have to remove the door panel to replace the speakers, just the grill. thanks though...
Old Nov 11, 2004 | 09:31 PM
RamSS/T's Avatar
Please email them to me too. ramsst1997@hotmail.com
Also does the whole panle have to be removed to gain access to the speakers or does the silver "speaker grill" come out?
Old Nov 11, 2004 | 09:33 PM
klassic's Avatar
Acording to the manual you have to remove the speakers first...
RamSS/T's Avatar
How do you remove the grill?
Old Nov 11, 2004 | 09:42 PM
klassic's Avatar
Sent.....
Old Nov 11, 2004 | 09:50 PM
Arrow
just stuck a screw driver underneath the grill/screen looking cover, and it pops off, revealing the speaker for easy replacement!
Old May 11, 2005 | 02:00 AM
bajabenedik's Avatar
and I'll email you the removal instructions from the manual... [/B]
Hey Klassic,
If you don't mind, could you email me the instructions for removing the door panels? My email address is: bajabenedik@yahoo.com
Appreciate it if you can do it.
Thanks in advance.
Old May 11, 2005 | 08:37 AM
04fx4Scab's Avatar
this does not work for the rear doors. if you try and pry the grille off you will break it. don't ask how i know!!
Old May 11, 2005 | 02:24 PM
jztbcz's Avatar
now that's just wrong ... ( ya it is )
Old May 11, 2005 | 03:11 PM
ChrisAdams's Avatar
To take the front door panels off you have to remove the speakers. And the bottom two white plastic nuts.
Speaker grill just pops off. Put a little black tape on the screwdriver to keep from scratching it.
On the Scab rear doors, take off the bottom two 7 mm screws, then pull straight out with Apollo like strength.
The Reg cab has just one small screw. And is even harder to pull away.
Chris
Old May 11, 2005 | 03:55 PM
04fx4Scab's Avatar
Chris
there were like 8 screws/bolts that i had to remove to get the rear door panel off. including the plastic trim around the window which is held to the door with tension clips.
Old May 11, 2005 | 07:52 PM
ChrisAdams's Avatar
My Bad, the reg cab is one screw, but my Manual shows 'up to' six screws for the rear of the supercab.
I was quoting another post, didn't think to check it against the manual.
Again, sorry for any problems.
Chris:o
Old May 25, 2005 | 02:31 PM
crudeau's Avatar
is this procedure the same for 05's? I'm looking to take off the front panels to install some new speaker wire runs, and so they are off for my window tinter.
Pretty much, pop the grill off, remove the speaker, remove two white nuts, and then lift the door panel off? I saw that there was a little access panel above the door handle, no screws behind this?
