Grill work
Old Oct 27, 2004 | 08:11 PM
plunds01's Avatar
Grill work
How do you separate the inner and outer grills from one another, i.e. on a Lariat splitting the gold and chrome sections? Looks like a bunch of tabs, any tips on getting the inner insert out without breaking anything?
Old Oct 27, 2004 | 08:27 PM
JohnAndDar's Avatar
plunds01,
Here's some information from RamSS/T:
Originally posted by RamSS/T
Swapping out the center is a lot easier than I thought it would be. You will HAVE TO bend the "locking tabs" under the clips so you can unsnap the grill from the shell. What I did was bend the tips of the tabs down with pair of needle nose pliers. Then unsnapped the old grill and snap the new one in...then if needed bend the locks back into place (or just leave them out...the center wont come loose if they arent used....the snaps hold the grille in place just fine). The thing I was happy about most was how easy it was to get the grille to line back up with the hood right....it pretty much just lined itself up.
Here is the link to the trhead that is from:
Check out what I did with my Grille
Old Oct 27, 2004 | 10:21 PM
SoundPer4mance's Avatar
that pretty much explains it, i used a flat head screwdriver to bend the lock tabs out of the way of the clips. i broke a few, but its still holding find without them
