Dealer's solution to vibration problem
Just read all the complaints about the vibration in the wheel. My truck has it too. It has just over 500 miles on it. goes in the shop tomorow. its a 4x4 5.4. Any solutions other than the driveshaft? thanks
badkarma38,
You will more than likely go through the TSB that Ford has on vibration. One word of advice. If the dealer says the problem is fixed don't believe them until you drive the truck and you are completely satisfied.
A Ford Engineer worked on my drive shaft for days. Each time he made an adjustment the vibration was either better or worst depending on the angle of the driveshaft, but never went away completely.
Ron
Ron
