20" Wheels, What tyres?
Old Oct 20, 2004 | 08:34 AM
dcee's Avatar
Question 20" Wheels, What tyres?
I am getting some 20" wheels and have been given an option of 275/45/20 or 285/50/20. Which one should I go for? I've an 04 4x4 Lariat.
Any input would be welcome.
Old Oct 20, 2004 | 12:26 PM
shane_wilson's Avatar
get the wider, thicker ones! - 285/50
Old Oct 20, 2004 | 02:15 PM
vpat's Avatar
Unhappy 20" tires
It depends on the width of the wheels. I put 22" wheels with 285/45/22 nitto tires on my new 04 r/c and they fit perfect. My rims are 9.5 wide though. Just FYI.
Old Oct 20, 2004 | 02:29 PM
Bullitt4711's Avatar
I say 285, which you can fit on either a 8.5" or 9.5" rim, but I say go with the wider! I had 305 on a 22x9.5 inch rim on my 03 Screw.
Old Oct 20, 2004 | 02:37 PM
dzervit's Avatar
Wider = better handleing as your putting more rubber to the road. However, it ALSO means more rolling resistance and in turn less MPG's for you. Minor, but always a factor. Plus, wider tires blow in heavy snow. Wider tires excel in soft stuff like sand.
Or if you don't give a hoot about anything I've said above, get the wider tires for a more aggressive look.
Old Oct 20, 2004 | 02:41 PM
You know we all care about you dzervit! You are my trainer and inspiration!
Old Oct 20, 2004 | 02:57 PM
dcee's Avatar
Thanks for all the input, just what I wanted to hear.
Looks like it's the 285's then.
Old Oct 20, 2004 | 03:40 PM
MX81's Avatar
In my opinion it seems like the 285/50/20 would look to small diameter wise on a 4x4
Old Oct 20, 2004 | 03:48 PM
cwcpm's Avatar
correct tire size
try 275/55-20
or 305-50-20
285 to short try to fill up those wheel wells
i went 275-60-20 fit fine no lift 33" tall
Old Oct 20, 2004 | 05:17 PM
wandell's Avatar
On a 4x4, I'd go with at least a 305/50-20 unless you have lowered the truck. These work out to be approximately 32 inches tall, which is the same height as the stock tires. The 285/50-20's will be about an inch shorter (approximately 31 inches).
Old Oct 20, 2004 | 06:18 PM
dcee's Avatar
Now I'm confused, need more posts. Should I ask to pay for bigger tyres?
Old Oct 20, 2004 | 07:02 PM
cwcpm's Avatar
Smile tire sizes
based on the tire sizes you posted who ever you are buying
them from is trying to sell you eagle gt2's the eagle ls is a much
better tire and sells for the same price sometimes cheaper
because it is factory on dodge and offered on some gm,s
dont settle for wrong size ....
Old Oct 20, 2004 | 07:16 PM
GB150's Avatar
I have 285/50/20's on my 2wd truck and I lowered the back end 2 inches and I think I should've gone with bigger tires. I'd say you definately need a larger tire.
Old Oct 22, 2004 | 05:50 AM
dcee's Avatar
Thanks again guys, I think I'll go with the 305/50/20.
Hope this is the right choice.
Old Oct 22, 2004 | 07:59 AM
RED WING NUT's Avatar
Nitto Terra Grapplers. 305/55-20. 33 inches tall.
