HELP: Loud Clicking Sound While Fan On
My '04 Lariat SCAB has been exhibiting a loud clicking sound, outside the truck while the fan is on. I've heard similar sounds in my other cars when the A/C engages, but in this case the A/C is not on. The clicking happens constantly, every 30 seconds to every couple of minutes while the fan is running. Sounds like something is turning on or off. It just can't be right...any thoughts?
EDIT: This is the interior fan, by the way...not the radiator fan, but the fan for the climate control.
-Michael
-Michael
The A/C compressor will turn on and off regardless of your A/C button setting depending on the direction that you have the air going for your climate control. Such settings are for defrost, panel/floor mix, and defrost/floor mix. I believe your owners manual mentions this as well.
Originally posted by MichaelF150
That makes sense...but does everybody's compressor make a loud enough sound to hear it with the windows up...it sounds like I have baseball cards in my spokes or something.
Mine is loud. I can hear it with the windows up. It doesn't bother me because I know what the noise is. If it was some noise that I had no idea where it was coming from, then it would bother me.
Cycles
Mine actually cycles every 10 seconds...
It goes click and then pssssssssssssssssss. Somewhat annoying.
I did have to take my truck in twice for A/C problems, so either that is normal or not???
Re: Cycles
