chime when turning key to startup
I bought a 2004 F-150 XLT Reg. Cab 5.4L V8 recently. When I start the engine the truck sounds 1 chime and says "check gauges" on the mini display for 1 or 2 seconds, then back to odometer, temp & compass. The door is closed and my seatbelt is on. Is this normal?
On a rare occasion, mine will do the same thing. Usually, it does it when I start it for the first time of the day. I would imagine that the PCM is just going through some diagnostics. The performance isn't hampered by this on mine, and i am assuming thai the same is true for your's...Kevin
All the chiming and lights being on ( all your lcons on the dash
should be lit too ) and the check gauges display are absolutely normal. It'll also say door ajar if it's not closed right also. I like the
set up myself. go reg. cab.
