Pics of leveling kit on a 4x2
Old Sep 30, 2004 | 11:10 AM
claytucc3's Avatar
Trying to decide if I want to do this. Mine is a 4x2 so I only need pics of those cause the 4x4 sit higher stock. I think
Old Sep 30, 2004 | 12:35 PM
Beaver Tricks's Avatar
I have Protech's 2.75" leveling kit on mine. See gallery for pics. Has 315/70/17 BFG's on it as well.
Old Sep 30, 2004 | 06:37 PM
GordoPanocho's Avatar
Registered User
If you have a few hundred bucks to spare, do it! It really gives the truck a better look IMO.
I did the Daystar 2.5" and then added new (slightly bigger) tires. Pics in my gallery (noted as before/after). Note, I had the leveling kit and the tires done the same day, so you won't see a simple before/after of the Daystar with stock tires.
Old Sep 30, 2004 | 06:41 PM
Bullitt4711's Avatar
Great looking setup!!!
Old Sep 30, 2004 | 11:46 PM
claytucc3's Avatar
That is a good looking truck. Is it a 4x2? Do you have a before pic by any chance
Old Oct 1, 2004 | 11:24 AM
Yes it is a 4x2.... and thanks for the comments.....
I will be updating my gallery with better pics in about 2 weeks. Rigth after my 6" suspension lift goes on. Those pics I have up now do not show my bull bar with light kit, wet okele seat covers, grill insert for opening under grill and emblem overlays
Old Oct 1, 2004 | 04:57 PM
freddytran's Avatar
Autospring 2" off eBay. Here ya go:
https://www.f150online.com/galleries....cfm?gnum=4472
Old Oct 1, 2004 | 08:18 PM
jpdadeo's Avatar
1 1/2" autospring kit
the rear is 1" higher than the front
Old Oct 1, 2004 | 09:28 PM
GSX-R750_K4's Avatar
Hey, where did you get those longhorn emblems? I am no exactly what you call a texas fan but I wonder if they make those wtih any other logos on them?
Also, what is the point of a leveling kit? Is it mostly for looks or is there some sort of performance enhancing qualities to it? I am kinda new to this truck thing, I don't take delivery until monday.
Old Oct 1, 2004 | 09:34 PM
claytucc3's Avatar
Did it hurt your ride quality or make your suspension noisey?
Old Oct 2, 2004 | 12:29 AM
freddytran's Avatar
The Autosprings bolt on top of the strut. It doesn't change the driveline or suspension really. I have felt no difference in ride quality. Plus it was pretty easy to install. Maybe an hour and half total.
There are two reasons I chose to install the leveling kit.
- First, the aesthetic reason: makes the truck sit up even in the front and back ... almost as if you put a mild lift kit all the way around. Notice that most true suspension lift kits even out the height in front and back.
- Second, the "meat" reason: eventually I am looking to putting some bigger tires on the stock 18" rims. I believe that some folks have already swapped 35"s under there. I was thinking more along the lines of 33" or 34".
HTH.
Old Oct 2, 2004 | 12:32 AM
claytucc3's Avatar
Yeah man thanks for the info. Did you need to realign the suspension?
Old Oct 2, 2004 | 12:33 AM
freddytran's Avatar
Yeah I had to get it realigned. The toe was off just a little.
Old Oct 2, 2004 | 12:34 AM
claytucc3's Avatar
Cool thanks man. Did you install them yourself? Also I see you have a 10" sub where the heck did you put that thing?
Old Oct 3, 2004 | 09:42 AM
freddytran's Avatar
I installed the Autospring with a help of a mechanic buddy. Simply lowered the strut and squeezed it in. Bolted it back up.
The 10" sub is under the back driver's seat in a box i built. I just finished building a dual 10" sub box, but I haven't figured out where and how to relocate my tire jack. A lot of people have done this already. DUPUIS relocated his jack into the engine bay.
