Security Code for 04
There are only 3,125 possbile combinations. 10 numbers and a 5-digit pin would normally be 100,000 possible combinations, however they put 2 numbers per button, basically making numbers 1-5. So, A way to calculate this is by N**x
where N is the number of digits possible (here, 5 different digits are
possible) 1 through 5
and x is the number of places available (here we have 5 places available
for a 5 digit number)
note the formula is N raised to the x power
meaning, 5**5
or 5 X 5 X 5 X 5 = 3,125 combinations
My point? Get crackin!!! Figure 5 seconds per combo you'd figure it out well under 4.5 hours!
meaning, 5**5
meaning, 5**5
meaning, 5**5
Originally posted by Motoguy79
Dzervit, you forgot to add in the time for the delay if you enter the wrong code more than 3 times in a row.
Hmmmm... wasn't sure there was one. What's the time? It can't be that long.. I've jammed codes in quickly before before I've remembered mine... never had an issue. Does it specify in the OM?
Will have to read that part again . Haven't lost the key or the FOB yet and i say YET LOL.
