Removing the Black Rubber Dash Tray
Old Aug 19, 2004 | 10:11 PM
Ranman's Avatar
Question Removing the Black Rubber Dash Tray
Does anyone know how to remove the black storage tray on the dash of the 04's? If so, please post the process. Thanks in advance.
Old Aug 19, 2004 | 10:14 PM
jpdadeo's Avatar
the rubber insert just pulls out
Old Aug 19, 2004 | 10:19 PM
dzervit's Avatar
Or if that fails, hook a tow strap up to it, and have a buddy with a F150 yank it out. Or C4. Yeah... C4! Meow!
Old Aug 19, 2004 | 10:44 PM
BREWDUDE's Avatar
Oh Boy...not the C4 again/ You remember what happened last time, dont you...
From a distance we all watch as Ranman sets off the C4
Old Aug 19, 2004 | 11:11 PM
papawoodie's Avatar
Re: Removing the Black Rubber Dash Tray
Yes, i seen how after i added an aftermarket cd player.
There is 2 screws holding it down. You need to remove the facia around the stock CD player, and the CD player (i think) to remove the screws holding it in. Maybe you can get around them without removing the cd player.
search for removing stock cd player, and if you follow that, you will see the screws pop right out at you.
(This is how its done on an 04 SuperCab XLT)
Old Aug 19, 2004 | 11:20 PM
BREWDUDE's Avatar
Well I cant imagine the rubber insert being installed differently in different model trucks, but I have the FX4 and mine just pulls right out. Theres 2 little rubber nipples underneath it that just pop in and out.
If you want I can go take some pics for you, but it should just pull right out.
Old Aug 20, 2004 | 07:34 AM
bigd999's Avatar
no screws in mine either, it just pulls right out
Old Aug 20, 2004 | 05:49 PM
jztbcz's Avatar
[QUOTE]Originally posted by BREWDUDE
[B]Oh Boy...
is it a button or a switch ? oh my !!!
Old Aug 20, 2004 | 06:13 PM
Ranman's Avatar
Thanks for the replys. I'm going to try pulling on mine some more. I tried to just pull it out last night and it seemed to be in there pretty tight. I thought I'd ask before I forced it.
Love the atomic cloud...
Old Aug 21, 2004 | 12:59 AM
ieee_raider's Avatar
I think there's a rubber boot within a plastic tray. To remove the rubber, just pull real hard and it'll come out, but you might never get it back in right.
To remove the entire tray, first remove the fascia around the cd player and climate controls. Then you'll see two screws at the top holding it in, I believe they're 5.5mm, but might be 6.5
Good luck!
Old Aug 21, 2004 | 11:12 AM
jpdadeo's Avatar
Good luck!
I take my rubber boot (insert) in and out all the time to clean it up and Armorall it. Never had a problem putting it back in. It’s directional though, only fits one way.
Old Aug 21, 2004 | 12:07 PM
stretchm36's Avatar
rubber tray
Just wondering, why do you want to remove the rubber tray???
Old Aug 21, 2004 | 01:55 PM
jpdadeo,
I said "might never", as in, if you break, bend, whatever it when you pull it out like that, it could not go back in right.
if you're careful, you should be fine.
Old Aug 21, 2004 | 02:44 PM
jpdadeo's Avatar
jpdadeo,
OK
Old Aug 21, 2004 | 02:47 PM
TonnyG's Avatar
Has anyone seen an aftermarket insert for it, I don't like the tray I would like to have an insert that is the same shape as the dashboard
TonnyG
