04 FX4 with 3" Skyjacker
Old Aug 6, 2004 | 05:23 PM
JZ150's Avatar
Here are some pictures of my new 04 FX4 with a 3" Skyjacker kit with 325 60 18 Nittos on 18X10 Evo wheels.
JZ150
[URL=https://www.f150online.com/galleries/mygallery.cfm?gnum=4550]
https://www.f150online.com/galleries....cfm?gnum=4550
Old Aug 6, 2004 | 05:30 PM
rodnash's Avatar
Looks good
Well done, I just picked up velocitys.
https://www.f150online.com/galleries....cfm?gnum=4543
Old Aug 6, 2004 | 07:12 PM
nsdq3's Avatar
Do you have any rubbing issues with the 33's and 10" wheels?
Old Aug 6, 2004 | 07:20 PM
lanceparkhurst's Avatar
Looks great.
Old Aug 6, 2004 | 08:37 PM
wandell's Avatar
That looks great JZ150!! Did the 3 inch Skyjacker come with components to lift the rear? From the adds that I've seen I thought it was just a set of replacement coilovers. Love that color combination!
Old Aug 6, 2004 | 09:24 PM
rodnash's Avatar
18x8.5 with 6.3 back space 40mm offset.
18x8.5 with 6.3 back spacing is the key.
Old Aug 7, 2004 | 12:08 AM
freddytran's Avatar
JZ150, where in Texas are you? Email me when you get a chance; I was wondering if you still had the factory FX4 wheels. freddytran@yahoo.com
Old Aug 7, 2004 | 01:22 AM
jaguar63's Avatar
Just perfect. Not to high, not too low!
Old Aug 7, 2004 | 01:49 AM
BREWDUDE's Avatar
Yeah..what he said...
Awesome set up. I think I just found the lift I want. Ive worried about the 4" or 6" being to much for my liking.After looking at your pics, I think thats what im gonna do.
Where did you get it?
How much did it cost?
Install...did you do it or have a shop do it?
How high is the top of the bed now?
Does the truck sit totally level now?
Old Aug 7, 2004 | 02:06 AM
jrich23's Avatar
Coilovers?? 2wd?
Has anybody used replacement coilovers on a 2wd yet? Just wondering what size tires you could fit and if some pix where available.
Old Aug 7, 2004 | 07:07 PM
JZ150's Avatar
Lots of Questions to answer here so I will try to get them all in one answer.
I am running 10" (18X10) wide wheels with 325 60 18 Nittos. There is no rubbing to speak of. I did tie the inner fender back a hair because locked to one side or the other, there was a slight slight rub on the inner fender. I thought about putting the 65's on this truck but thought that was too much tire to stuff up under the wheel well so I stuckwith the 60's. I am not a big fan of stuffing too much tire under a truck. I guess I like the ratio of tire heigth, clearance from tire to wheel well and the size of wheel to look like it belongs. Too many guys stuff too much tire up uner a truck and I think it looks out of balance.
The 3' Skyjacker does come with two springs for the rear to bring it up. I was afraid that it was going to keep the nose heavy look with the rear springs but I am really happy with the ride heigth. Its sits just the right amount lower in the rear than the front. My brother did all the work for me and he was a little concerned that the front coils were going to make the ride too stiff but it rides just like the stock coils.
Skyjacker recommends but does not include a set of replacement rear shocks. They say that if you plan to flex the suspension much that you should replace the shocks. It will keep you from bottoming the shocks out.
The kit is about $500 plus a set of rear shocks. My brother does this kind of work in his spare time so I bought it all through him. He is a Senior Master Technician at a Ford dealer in Pennslyvania. Needless to say, I bought all my stuff at his cost. I had about $3800 total including the wheels and tire invested. (For all you guys in Northwestern PA, my brother is the guy to have install your stuff. He does some pretty incredible stuff.)
Lastly- I do have the stock 18" FX4 wheels and tires with ZERO miles on them available.
I am in the Wichita Falls area.
JZ150
Old Aug 8, 2004 | 02:42 AM
pa_wolf62's Avatar
Where in NW Pa. ? What dealership?
Old Aug 9, 2004 | 08:41 AM
JZ150's Avatar
The Ford dealer in Kane PA
Old Aug 13, 2004 | 07:57 PM
barberos's Avatar
Can you just install the sky jacker front lift (and not the rear) Why skyjacker over the spacers that others are using ?
Truck looks great. Looking to get the same look with a little less lift in the back.
Old Aug 13, 2004 | 08:00 PM
barberos's Avatar
can JZ 150 and rodnash add front shots of your trucks ? I would like to see the difference between the two wheel widths.
