Tsb #17759
Old Jul 28, 2004 | 02:27 AM
04screwxlt's Avatar
Tsb #17759
Has anyone experienced anything like this? My cooling fan lopes (sounds like a rolling idle) from the time the truck is started in the morning until it becomes warm. Is this normal? Can someone provide the full text to this bulletin?
Service Bulletin Num : 17759 Date of Bulletin: APR 01, 2004
NHTSA Item Number: 10008249
Component: ENGINE AND ENGINE COOLING:COOLING SYSTEM:FAN
Summary:
ENGINE COOLING FAN NOISE THAT SOUNDS LIKE A ROLLING IDLE. *TT
Old Jul 28, 2004 | 07:59 PM
Quintin's Avatar
"Engineering is aware of the concern and is currently working on a solution. Do not attempt any repairs at this time."
Ford don't know what it is just yet, in the bulletin itself they don't advise replacing the fan clutch or any of the FEAD components. They say to sit tight and monitor broadcast messages for a fix sooner or later.
Old Jul 28, 2004 | 08:07 PM
04screwxlt's Avatar
Quintin,
Thanks for the info man. So I guess this is something that I will need to have fixed eventually.
Old Jul 28, 2004 | 08:08 PM
jpdadeo's Avatar
This is the first I’ve heard of that problem. I don’t hear it on mine.
Old Jul 28, 2004 | 08:24 PM
04screwxlt's Avatar
I have had a few problems with my truck so I tend to check the Service Bulletins every once in a while to see whats out there. Here is what I have had done
* Clutch pak
* Ring and Pinion gears, which so far has solved the whine
* Front crossmember and swaybar were loose from factory
which threw the alignment out pretty bad and made for
some terrible crunching sounds when driving over bumps etc..
* Dealer screwed up alignment and had to redo it. really
munched up my tires.
* A few rattles on the inside
* Steering wheel nibble was solved by tightening up the front
suspension and road force balancing the tire.
The truck has been in the shop for a total of 15 days since I bought it.
Otherwise I love it. Best looking/running truck I have ever owned.
Mine was built 10/03. I kinda wish I would have waited for the '05 model.
Old Jul 28, 2004 | 08:30 PM
jpdadeo's Avatar
* Clutch pak
That’s a bummer; lot of sh*t wrong. My truck is trouble free at 9,800 miles; hope it stays that way.
Old Jan 17, 2005 | 09:21 PM
ftkcignusx1's Avatar
'04 F150 FX4 Crew 5.4 07/04 build date - KC. I think my truck defines SSM 17759. The first 10-15 mints after starting, it's like someone is sitting back smiling with a switch turning the fan off, then on, then off, then on. Each time it comes on, it revs from low to high, then seems to shut off, then cycles like this over and over again. You don't want to be showing the truck off just after starting it that is for sure, especially to a non-Ford (which I used to be) owner. After the initial 10-15 minutes or so, it becomes much less noticeable, but still cycles. I'm not sure why it is taking Ford so long to resolve this problem - anyone know? I just checked today while at the dealer, no new information from Ford.
I've had some other issues, wind noise (fixed by placing a silicon bead between the windshield and the cosmetic 1/8" strip of molding along the top of the windshield), door rattle (inside cable was loose), sluggish throttle response (fixed noticeably by the latest PCM update). Other than that, very nice truck. Of course, I haven't had any of the steering or power train vibrations (yet -knock on wood .
Old Jan 17, 2005 | 11:52 PM
kevhunt's Avatar
Mine does it. Only for about 2-3 minutes on cold mornings...Kevin
Old Jan 18, 2005 | 12:08 AM
Corpsie's Avatar
Step 1: Find the TRUE source of the problem
Step 2: Develop a fix
Step 3: Test the fix so it can be signed off
Step 4: Develop the documentation for the fix
Step 5: Roll out the fix.
Remember, fixing a low temp fan problems can possibly cause bad things to occur at high temp. All the appropriate testing needs to be done.
Old Jan 18, 2005 | 09:36 AM
I believe the time delta of 10-15 minutes vs 2-3 minutes has to do with the weather difference between WI and OK. Yesterday morning it was -23 Fahrenheit (absolute).
Old Jan 18, 2005 | 07:01 PM
Quintin's Avatar
Uncle Henry's still working on it...
17759 2004 F-150 - ENGINE COOLING FAN NOISE THAT SOUNDS LIKE A ROLLING IDLE
SOME 2004 F-150 VEHICLES EQUIPPED WITH EITHER A 5.4L OR 4.6L ENGINE MAY EXHIBIT A NOISE FROM THE ENGINE COOLING FAN THAT SOUNDS LIKE A ROLLING ENGINE IDLE, MOST NOTICEABLE JUST AFTER A COLD ENGINE STARTUP AND BEFORE THE FAN CLUTCH HAS WARMED UP. THE CAUSE OF THE CONDITION CAN BE VERIFIED BY STARTING A COLD VEHICLE, PUTTING THE TRANSMISSION INTO GEAR AND LISTENING FOR A REPEATED COOLING FAN NOISE INCREASE AND DECREASE. ENGINEERING IS CURRENTLY INVESTIGATING THIS CONCERN. REPLACING THE FAN CLUTCH OR OTHER FRONT END ACCESSORY DRIVE (FEAD) COMPONENTS WILL NOT SOLVE THIS CONDITION, SO DO NOT ATTEMPT REPAIR. IF THE ENGINE HAS AN ACTUAL ROLLING IDLE, FOLLOW NORMAL DIAGNOSTICS. PLEASE MONITOR OASIS FOR UPDATES.
EFFECTIVE DATE: 04/30/2004
