Front license plate removal
it just depends if you want to be able to put it back on or not. I took mine off never to put it back on again. the top has 2 hook looking things that hook on top of the bumber. just take a screw driver and bend the plastic up over the bumber and pull. the bottom you will just need to pull and brake off. its attached some how and i didn't take the time to find out where. so i broke the 2 little round things on the bottom of the plate holder.
if you have an after market grill it looks a lot nicer. I sitll have my front plate with me just in case I get pulled over.
the underside is also hooked on with 2 plastic hooks. if you go under the car and pull back the rubber shroud type stuff you can see where the piece comes through and hooks. even in the daylight a flashlight is helpful and a screwdriver is all it takes. it took me a while to understand how it was hooked but you eventually get it. if you need a pic let me know my camera is dead right now
