How to determine build date
Can anyone tell me how to determine when my truck was built? I've done some research about the VIN number and would like to know what DAY and MONTH it was built. Any hints or suggestions will be depreciated, I mean, appreciated.....
I just checked on the door jamb and the date was 06/04. So, I guess its safe to say that my truck was built in June. Being a later build date, I wonder if Ford has made adjustments since the 2004 production model began? The reason being, some have had vibration issues and little problems here and there, but so far mine seems to be a very solid truck.
The sticker on your engine has year, month and day.
The engines don't sit around for more than 48 hours.
At the very least you can eliminate those days in June before the engine build.
Hope it doesn't say the 1st......
Go to your Dealer and ask them for an Oasis Report , they will print you a copy if you like. This report will tell you the actual build Day , when the Truck was put into service and a record of all warranty work performed on the truck.
