Ford Molded Splash Guards
Old Jun 22, 2004 | 02:26 PM
Thayer's Avatar
I know a few people have reported problems installing Ford mud guards on the Lariats with step bars. I just put a set on and had no clearance issues what so ever with my Westin platinums. Only problem was the already mentioned mis-drilled holes on the rear guards but that was no big deal. Will post pics when I get settled in AZ.
Old Jun 22, 2004 | 02:35 PM
Dupuis's Avatar
The problem is only with the factory black running boards.
Old Jun 22, 2004 | 07:31 PM
lariatf150's Avatar
I have the black platform running boards and the official Ford splash guards from the dealer. The dealer installed mine. Only thing I noticed was the bottom screws were not installed because the running board sort of butts up against the splash guard. It doesn't seem to be a problem because they fit in there so snug. They look and fit fine on mine.
This picture is a little dark, but this is how they look on mine:
Old Jun 25, 2004 | 10:05 AM
Guigster's Avatar
Re: Ford Molded Splash Guards
The holes are mis-drilled? In what way? I want to tell my dealer because I'm thinking of getting them and having them install them.
Old Jun 25, 2004 | 02:12 PM
Thayer's Avatar
One of the holes on the rear flaps does not match up with the hole in the truck. I found it easier to re-drill the flap instead of the truck.
Old Jun 25, 2004 | 02:32 PM
momalle1's Avatar
The front molded flaps will not fit at all if you don't have the wheel lip moldings. I have heard of people with the platform running boards cutting them, not sure I want to do that though.
Old Jun 25, 2004 | 04:29 PM
Guigster's Avatar
If you DON'T have them, right? I have an FX4 with the lip molding, so I should be fine?
Old Jun 25, 2004 | 04:37 PM
momalle1's Avatar
Yes, you should have the same situation as LariatF150
Old Jun 25, 2004 | 05:19 PM
Thayer's Avatar
They make flaps for trucks both with and without wheel lip molding. The only clearance issues I've heard of is with running boards. I have no problems with Westin bars.
Old Jun 25, 2004 | 06:09 PM
yan's Avatar
yan
I have Westin nerf bars on my 04 Reg cab and the Ford molded splash guards wouldn't fit on the front.
