The BRAKE Master Thread
Old Jun 13, 2004 | 04:18 PM
jztbcz's Avatar
I have quiet brakes and working ac , BUT i couldn't avoid the
rear-end shudder bug.The dealer gets too play with it on tues.
try the advice of baja150 and spread some break quiet on there.
'04 f-150 xlt 4x4
reg cab flareside
Old Jun 13, 2004 | 06:33 PM
baja150's Avatar
Originally posted by TytheBeerSlayer
I can go to a car wash and clean them as best as I can but to no prevail, the notorious squeal.
Well that was a mistake. Your brakes are factory lubricated to prevent squeal. Washing them at the car wash which I'm assuming you mean a power washer type would only worsen the situation.
DID YOU READ MY REPLY??? YOU NEED TO LUBRICATE THEM. YES I BELIEVE YOU HAVE/HAD A PROBLEM, BUT WASHING THEM AT THE CAR WASH ONLY MADE IT WORSE BY WASHING OUT THE LUBRICANT. GO BUY SOME BRAKE QUIET AND YOUR PROBLEM WILL BE SOLVED. NOTHING IS GOING TO GET SOLVED BY MAKING INSINUATING POSTS THAT OTHER MEMBERS ARE LYING ABOUT THIER BRAKE PERFORMANCE.
Old Jun 13, 2004 | 07:17 PM
jpdadeo's Avatar
Try the brake spray lubricant
Old Jun 13, 2004 | 07:59 PM
TytheBeerSlayer's Avatar
OK fellas off to Autozone to buy the lube, thanks.
Old Jun 13, 2004 | 09:18 PM
CTBob's Avatar
100 miles on my new truck and notice the brake squeal only in reverse. Will see what happens after a few thousand miles.
Old Jun 13, 2004 | 09:42 PM
RibbonSpeakers's Avatar
Originally posted by 04 RED LARIAT
I Most break noise is caused by harmonic vibrations between the non-friction material of the pad and other parts that they touch.
The squealing is NOT coming from the pad to rotor so changing to ceramic will not
I am not a professional mechanic, but I know a lot about vibration & harmonics from my many years in audio & music. The above statement might be partially wrong. It may be absolutely correct, & motorcycle service bulletins agree, that the vibrating surfaces causing the noise are the pad backing & the piston surface. It is also possible that the composition of the pad material can change the way it interacts with the disc, & subsequently change the harmonics of the pad's rear backing plate, which then can affect the noise. On many motorycles they use a spring to damp this exact vibration, to minimize the high frequency vibration (squeeling is high frequency). On the other hand, it is very possible that a goop made just for the purpose of preventing brake squeel should solve the problem (between the pad back plate & the piston).
Hope you fix it soon, sounds like that can literally drive you nuts with their frequency & intensity. In acoustics we call it the "threshold of pain" for a reason.
Old Jun 14, 2004 | 10:53 AM
Guigster's Avatar
I have had the brake squeal for quite some time. Although, I did just get over 10,000 miles and it has diminished some. Not all. Don't get me wrong there is still some squealing, but it was much worse a few thousand miles ago. It doesn't do it all the time now. Unless I'm just adjusting the pressure I apply to the brake to compensate because I know what position it really squeals at.
I've always thought that the squealing comes from the pad vibrating against what it's mounted to. Whenever I did my own brakes on other vehicles, I used to put this glue/paste/gel, something gooey, on the back of the pads to keep them from vibrating, thus keeping them from squealing.
This sounds true to me...which now that I think about it, disproves the dealer's theory of "All metal pads squeal."
It's not the face of the pad. It's the back. Because when I brake hard, it doesn't squeal. The pad has a lot of pressure on it. It's only when I do the slow roll to a stop that I get the squeal.
Old Jun 14, 2004 | 11:10 AM
jaguar63's Avatar
Yea, I'll ad to that- My brakes squealed from 15 miles through 4,500 pretty consistantly (FX4 Supercab). It is less now. However, I plan on putting the lube or goop on the backside of the pads (metal to metal, pad backing plate to piston) area. Yea, I agree with Guigster, those dealers (service department) do not know what they are talking about, when they say "all metallic pads squeal". I put high concentration metallic pads on my Corvette and eliminated the squeal over the stock pads. They came with a high temperature plastic bonded on the metal to metal contact area.
Old Jun 14, 2004 | 11:34 AM
petard's Avatar
Mine squeal. At some point I'll have the dealer look into it or my local mechanic. I thought it might be the stock brake pads. Or the fact that I ride my brakes as I slowly squeeze the truck into the garage. I have about 3 inches of clearance on three sides. It's a tight fit.
Old Jun 14, 2004 | 03:30 PM
PALongbow's Avatar
My truck is going in for squealing breaks on Saturday. My dealer is aware of the problem. We will see what they do to resolve the issue. I have an FX4 with 3,000 miles on it. Also I have the vibration and lack of AC problem as well. The dealer is going to address those issues as well.
Ron
Old Jun 15, 2004 | 12:42 AM
I went down to the local Autozone and they were out of the brake lube. Guess there must be a lot of 04 Fords in the neighborhood, heh. Then I started thinking, why should I be messing with this? I'm eating Spam and drinking ditchwater to pay for this thing why should I mess with it, so I made an appointment with another dealer's service department so we'll see where that gets me. The verdict will be in Saturday. I appreciate all the advice fellas.
Old Nov 29, 2005 | 11:56 AM
boomer08's Avatar
Originally Posted by TytheBeerSlayer
So let me get this strait... None of you guys have the brake trouble even though I've seen 10 threads about people complaining about it. OK then.
I have over 24000 miles with no squeal at all. But I think I will be putting on ceramic pads in the near future.
Old Nov 29, 2005 | 12:05 PM
EOJRR1's Avatar
I had some squealing and I mentioned it to the dealer when I took it in for free oil change, also mentioned that when I got on it when passing or on entrance ramps that it had some throttle lag.
PCM flash, new front rotors and new front calipers and all problems appear to be gone at this time.
'05 FX4 7,500 miles.
lariatf150's Avatar
Cheap version of ceramic pads from Advance Auto Parts fixed my dust and squeal problem IMMEDIATELY End of story.
Old Nov 29, 2005 | 12:53 PM
blkscrew5.4's Avatar
My '05 has 13k miles on it and has squeeked and vibrated from about 500 or so also. the dealer has replaced all four rotors, helped a little withe the squuek and no more vibe, tried the lube on the areas suggested in here, helped a little more. use to squeek ALL the time stopping at lights, slowing down in parking lots, d-thru's etc., now it pretty much only does it in reverse and on extended braking periods at very slow speeds. any suggs. I'm hoping to get some ceramics (mainly for the horrid amounts of brown dust I clean off the rims every couple of days) for the beast for Xmas. so nix that one
Thanx
