Wheel Alignment specs needed (daystar)
I am installing my Daystar kit in my 04 lariat Super Crew 4X4. I was told to need to get the wheel specs to re-align my front end. If not my dealership said it would take a couple of hours to properly align the front wheels.
Does anybody have the wheels specs for the front end??
Thanks in advance.
Jay.
Thanks in advance.
Jay.
204-00-1 204-00-1 Suspension System
SPECIFICATIONS
Alignment Specifications
Item LH RH Total/Split
2WD Regular Cab
Caster 4.4° ± 1.0° 4.4° ± 1.0° 0° ± 0.75°
Camber -0.2° ± 0.75° -0.2° ± 0.75° 0° ± 0.75°
Total toe (front) — — 0.15° ± 0.25°
Total toe (rear) — — 0.0° ± 0.20°
Thrust angle — — 0.0° ± 0.30°
2WD SuperCab
Caster 4.6° ± 1.0° 4.6° ± 1.0° 0° ± 0.75°
2WD Crew Cab
4WD Regular Cab
Caster 4.3° ± 1.0° 4.3° ± 1.0° 0° ± 0.75°
4WD SuperCab
4WD Crew Cab
Copyright ã 2003, Ford Motor Company
Last updated: 10/8/2003 2004 F150, 12/2003
204-00-2 204-00-2 Suspension System
SPECIFICATIONS (Continued)
Model Specification Model Specification
2WD Regular Cab 4WD Regular Cab
126-in wheel 126-in wheel
base, 4.6L base, 4.6L
Front 115 mm (4.5 in) ± 12 mm (0.5 in) Front 111 mm (4.37 in) ± 12 mm (0.5 in)
Rear 185 mm (7.2 in) ± 12 mm (0.5 in) Rear 186 mm (7.32 in) ± 12 mm (0.5 in)
base, 5.4L base, 5.4L
Front 112 mm (4.4 in) ± 12 mm (0.5 in) Front 116 mm (4.56 in) ± 12 mm (0.5 in)
Rear 185 mm (7.2 in) ± 12 mm (0.5 in) Rear 187 mm (7.36 in) ± 12 mm (0.5 in)
145-in wheel 145-in wheel
Front 102 mm (4.01 in) ± 12 mm (0.5 in) Front 111 mm (4.37 in) ± 12 mm (0.5 in)
Rear 186 mm (7.32 in) ± 12 mm (0.5 in) Rear 187 mm (7.36 in) ± 12 mm (0.5 in)
Front 105 mm (4.13 in) ± 12 mm (0.5 in) Front 109 mm (4.29 in) ± 12 mm (0.5 in)
Rear 184 mm (7.24 in) ± 12 mm (0.5 in) Rear 187 mm (7.36 in) ± 12 mm (0.5 in)
2WD SuperCab 4WD SuperCab
133-in wheel 133-in wheel
Front 112 mm (4.4 in) ± 12 mm (0.5 in) Front 115 mm (4.52 in) ± 12 mm (0.5 in)
Rear 172 mm (6.77 in) ± 12 mm (0.5 in) Rear 176 mm (6.92 in) ± 12 mm (0.5 in)
Front 114 mm (4.48 in) ± 12 mm (0.5 in) Front 118 mm (4.64 in) ± 12 mm (0.5 in)
Rear 175 mm (6.88 in) ± 12 mm (0.5 in) Rear 173 mm (6.81 in) ± 12 mm (0.5 in)
Rear 175 mm (6.88 in) ± 12 mm (0.5 in) Rear 171 mm (6.73 in) ± 12 mm (0.5 in)
Front 109 mm (4.29 in) ± 12 mm (0.5 in) Front 119 mm (4.68 in) ± 12 mm (0.5 in)
Rear 174 mm (6.85 in) ± 12 mm (0.5 in) Rear 177 mm (6.96 in) ± 12 mm (0.5 in)
2WD Crew Cab 4WD Crew Cab
138-in wheel 138-in wheel
Front 112 mm (4.4 in) ± 12 mm (0.5 in) Front 117 mm (4.6 in) ± 12 mm (0.5 in)
Rear 174 mm (6.85 in) ± 12 mm (0.5 in) Rear 174 mm (6.85 in) ± 12 mm (0.5 in)
Front 110 mm (4.33 in) ± 12 mm (0.5 in) Front 119 mm (4.68 in) ± 12 mm (0.5 in)
Rear 171 mm (6.73 in) ± 12 mm (0.5 in) Rear 173 mm (6.81 in) ± 12 mm (0.5 in)
2004 F150, 12/2003
204-00-3 204-00-3 Suspension System
General Specifications (Continued) Model Specification
2WD Heavy Duty Item Specification
Regular cab, Dogtracking — maximum 30 mm (1.18 in)
145-in wheel (centerline of front tires
base, 5.4L compared to centerline of
rear tires) Front 117 mm (4.6 in) ± 12 mm (0.5 in)
Ball Joint End Play Rear 199 mm (7.83 in) ± 12 mm (0.5 in)
Lower ball joint — 1.5 mm (0.06 in) SuperCab,
maximum vertical 163-in wheel
base, 5.4L Upper ball joint — 1.5 mm (0.06 in)
maximum vertical Front 107 mm (4.21 in) ± 12 mm (0.5 in)
Cleaners — Wheel Rear 190 mm (7.48 in) ± 12 mm (0.5 in)
Custom Bright Metal ESR-M5B194-B 4WD Heavy Duty
Cleaner 8A-19522-A
Regular cab,
Tire Balance Weight 145-in wheel
base, 5.4L Maximum balance weight 170 g (6.0 oz)
(total of inner and outer Front 128 mm (5.03 in) ± 12 mm (0.5 in)
wheel flange)
Rear 196 mm (7.71 in) ± 12 mm (0.5 in)
Tire Inflation
SuperCab,
Tires See safety certification 163-in wheel
sticker located on driver base, 5.4L
door jamb.
Torque Specifications
Regular cab,
snow plow, Description Nm lb-ft
145-in wheel
Wheel nuts 204 150 base, 5.4L
Jounce bumper-to-frame bolt 35 26 Front 128 mm (5.03 in) ± 12 mm (0.5 in)
Front Suspension Rear 196 mm (7.71 in) ± 12 mm (0.5 in)
Wheel hub-to-wheel knuckle 200 148 SuperCab,
bolts snow plow,
163-in wheel Tie-rod end nut 150 111
base, 5.4L Front axle-to-wheel hub nut 27 20
Front 121 mm (4.76 in) ± 12 mm (0.5 in) (4x4)
Rear 187 mm (7.36 in) ± 12 mm (0.5 in) Upper ball joint nut 115 85
Upper arm-to-frame nuts 150 111
Lower ball joint nut 150 111 General Specifications
Lower arm-to-frame bolt and 300 222 Item Specification
nut
Vehicle Lean (side-to-side height differences)
Front shock absorber rod nut, 30 22
Front — maximum 7 mm (0.28 in) upper mount
Rear — maximum 8 mm (0.32 in) Shock absorber upper 48 35
mounting plate-to-frame nuts Wheel Track
(M10)
Wheel track 0.6 mm (0.02 in)
Shock absorber-to-lower arm 475 351
Dogtracking bolt and nut (M20)
Stabilizer bar bracket-to-frame 48 35
bolts
2004 F150, 12/2003
204-00-4 204-00-4 Suspension System
Torque Specifications (Continued) Torque Specifications (Continued)
Description Nm lb-ft Description Nm lb-ft
Stabilizer bar-to-link nut 133 98 Shock absorber, upper 90 66
Stabilizer bar-to-link to lower 90 66 Shock absorber, lower 90 66
control arm nut Rear caliper bolts 32 24
Anti-lock brake sensor bolt 18 13 U-bolt nuts (light duty) 115 85
Caliper anchor plate-to-wheel 200 148 U-bolt nuts (heavy duty) 250 184
knuckle bolts
Spring/frame nut (front) 300 222
Caliper-to-anchor plate bolts 32 24
Spring/shackle nut (rear) 133 98
Rear Suspension
Spring shackle/frame nut 133 98
2004 F150, 12/2003
SPECIFICATIONS
2WD Regular Cab
2WD SuperCab
2WD Crew Cab
4WD Regular Cab
4WD SuperCab
4WD Crew Cab
2004 F150, 12/2003
Cleaner 8A-19522-A
Regular cab,
wheel flange)
Tire Inflation
SuperCab,
door jamb.
Regular cab,
145-in wheel
bolts snow plow,
nut
(M10)
bolts
2004 F150, 12/2003
knuckle bolts
Rear Suspension
2004 F150, 12/2003
That's long list. Thanks a million. Also 20044Bill let me know how your kit turns out.
