"CAN Flasher"
Originally posted by Dusty1
How much do these "flashers" usually cost? What kind of cool stuff can you do with them?
Superchips website 1715 Max Micro Tuner
Troyer Performance 1715 description page
I was on the phone with Justin from Superchips Custom Technology on Thursday discussing the performance reflash correction for my truck's PCM and asked him about the CAN Flasher. He just said it would be out "soon".
My PCM was flashed
SCT's flash tune coming out, eliminates the lag completly and also improves shifting. I have it for testing and it made it a completly different ride. It now feel like there is 300 hp (now 325) under the hood. It has much improved towing ability. I can still use reg gas but for more power you would use the higher octane. I use the mid grade 89 octane. IMO it's the only mod you can't do without.
JE
JE
My message to Superchips:
"I wanted to find out if there is an anticipated availability date for a performance flasher/tuner for the new 2004 F150 (5.4L 3v). Will it be comparable to the 1715 tuner as far as features and programming options (and diagnostic checks)?"
Their reply:
"A Superchips Microtuner should be available for your application in the June/July. Thanks for the inquiry."
They didn't provide any information about features, but I guess we only have to wait another month or so to find out.
John
Their reply:
John
this is something my dad should get for his f150 IF he decides to go pick it up. Nice thing is, u can set the truck back to stock anytime u want to. Plus u can tune it for reg gas, mid range, and premium gas.
JE
hmm, i wasnt aware of that, but i think using 89 octane would be a compromise, because i believe the troyan performance guy said 10-15 hp gain with 87 octane, so u figure prolly 15-20 with 89, and 20-25 or so with 91. Soudns like these trucks respond well to the PCM flash. You can set it back to stock at any time, so if u need some dealer work done, just flash it back to stock
JE
Originally posted by ristuccia
jagged edge, this more aggressive tune, you make it sound like its an entirly separate tuner from the one discussed in this thread.
JE
