The New Navigation Unit
Old May 4, 2004 | 02:14 PM
Robcee's Avatar
I have had that head unit on order from Hi Fi Buys for about 8 weeks. It is supposedly coming in next Monday. Does the unit have a memory stick slot? I was under the impression that it did, and the other two Eclipse units do. It really looks great.. I intend to take out the tray on the dash and replace it with a center channel so I can have true 5.1 sound... We'll see....
Old May 4, 2004 | 08:10 PM
pepatrick's Avatar
The one with navigation does not have a memory stick. It is an awesome unit though. I am very pleased with it.
Philip
Old May 5, 2004 | 10:11 AM
Robcee's Avatar
I had my speakers (with factory head unit and step downs, yuk) installed yesterday, finally. I had been waiting on the AVN2454 but got tired of the facory speakers. I put 4 6 1/2" JL Audio subs under the rear seat, along with the JL 500/5 amplifier. I have MB Quart Q series 5 1/4 seperates in the front doors, and some rather inexpensive coax's in the rear doors. It sounds a lot better than the factory system, but running through the factory head unit and the stepdowns gives me a low voltage signal to the amp and a lot of nasty noise that turns into hearing threatening distortion at any respectable volume. The Eclipse unit is supposed to come in on the 10th, so I will post pictures if it does (and if I can figure out how to post pictures).
Old Oct 31, 2004 | 10:54 PM
wirelessness's Avatar
Question
Can you still use the stearing wheel controls with the Eclipse?
Thanks!!!
Old Nov 1, 2004 | 06:50 AM
loosebolt's Avatar
Did you find a way to bypass the wiring so you can watch DVD's while the truck is in motion?
Old Nov 1, 2004 | 10:02 PM
dzervit's Avatar
Ground the sensor to the parking break.
With an aftermarket adapter, yet. Search and you'll get answers.
Old Nov 1, 2004 | 10:50 PM
pepatrick's Avatar
Also..got rid of the AVN2454 and replaced it with Alpine IVA-D300 and Alpine Navigation unit. The Alpine is a much better set up..and I like the the touch screen on the Alpine better. And...yes...the steering controls still work with the pax-1.
Philip
Old Nov 1, 2004 | 11:15 PM
COFX4's Avatar
Does that Eclipse unit have a hard drive so you basically dont even need cd's?? I thought i read that somewhere...anyhow, that is one sick setup...I'd be afraid to leave it!!
Old Nov 1, 2004 | 11:20 PM
Bullitt4711's Avatar
That makes a sweet setup!!!
Old Nov 2, 2004 | 10:47 AM
three_green's Avatar
Philip
Hey pepatrick, got any pics of the new setup? I'd like to see it!!!
Old Nov 2, 2004 | 10:52 AM
dzervit's Avatar
No hard drive in that unit. I does, however, employ TWO optical drives. One slot for your tunes, the other for DVDs or Nav Disk. Hella-cool.
Old Nov 2, 2004 | 10:53 AM
dzervit's Avatar
That makes two of us. WTF are the PICS?!!!
Old Nov 2, 2004 | 12:16 PM
ShadowedFX4's Avatar
am i reading this right?! did you say the eclipse is an awesome unit yet you just switched to an alpine setup??? if so, what was the reason for the swap?
I'm getting the kenwood unit installed this month. Even though you have to hide the nav drive somewhere else as someone said on this thread, that's ok.... because atleast you have a dedicated drive just for nav. alone. THe eclipse is good, but lacks in the nav dept. because that single headunit had to support/handle everything.... cd/dvd/nav
Old Nov 3, 2004 | 03:45 PM
freedom9ner's Avatar
We need some pics up in this joint. My imagination isn't what it used to be. Pitures tell a thousand words.
Old Nov 3, 2004 | 08:05 PM
pepatrick's Avatar
I will post the pics when I get back in town. I switched to the Alpine unit because I like the touch screen better. The nav unit is more acurate, however it is not quite as easy to use as the Eclipse.
Another thing, the eclipse has two drive units in it. One is for CD/MP3 and the other is dedicated to Navigation. It will also play DVD movies.
Philip
