Flowmaster 40 series duals with PICS!
supposedly, if I read the manual right when a battery is changed the system has to relearn idle markings. after any changes on the truck dealing with the intake/exhaust system I would assume you should do the same.With the exhaust, you will most likely get more CFM through the engine and lower backpressure. you should disconnect the battery terminal,wait 5 minutes then "as the manual says"
1. With the vehicle at a complete stop, set the parking brake.
2. Put the gearshift in P (Park) (automatic transmission) turn off all accessories and start the engine.
3. Run the engine until it reaches normal operating temperature.
4. Allow the engine to idle for at least one minute.
5. Turn the A/C on and allow the engine to idle for at least one minute.
6. Drive the vehicle to complete the relearning process.
• The vehicle may need to be driven 16 km (10 miles) or more to
relearn the idle and fuel trim strategy.
• If you do not allow the engine to relearn its idle trim, the idle
quality of your vehicle may be adversely affected until the idle
trim is eventually relearned.
If the battery has been disconnected or a new battery has been installed,
the clock and the preset radio stations must be reset once the battery is
reconnected.
Maintenance and Specifications
235
reconnected.
235
Thanks for the info, I thought I heard something about leaving the lights on for a certain amount of time after the battery was disconnected or something? Another stupid question...When disconnecting the battery, should I do the positive, the negative, or both.
positron
I was hoping that someone would put one of the Billy Boat systems on their new 04. I've been looking at those. Which system are you getting and did you purchase direct? I really wanted to install the Gibson dual sport but it requires removal of the spare tire, no way.. I'm looking for something not to loud but looks and sounds good. The BB system should be top notch for the advertised price..
L Squared,
I got the b&b direct. it should be here by next week and I will be putting it on on Friday (must call in sick from work for this)
I toyed betwen the corsa and the billyboat. in the end the billyboats have the best sound, i think.
will post pics
will post pics
I think I have 2 or 2.5 inch pipes with 3 inch tips. I didn't really ask because I really didn't have a preference. I still think it sounds great. If you want something that you can't hear in the cab at highway speed get something else. The only time I don't hear anything at all is when I'm coasting. But even though I can hear it, its not overpowering or make it hard to talk to people or anything like that. Its the best background music around!
Re: JamzWayne
Originally posted by TexfordD
are you here in DFW?...go to Harrys Hot Rod in Grand Prarie for the Flowmaster...then ask them where A&B Muffler is and tell Roberto I sent 'ya..he'll give you a good deal on the install.
I used to live in G.P.
Originally posted by BlkSuperCrew
I was going to go with the flowmaster series 40, but after talking to my buddy at the exhaust show I went with no muffler. The four cats cuts down on the sound quite a bit. It sounds pretty comparable to an older truck with glasspacks, nice deep sound and awesome when you get on it. Cruising on the highway it is a mild rumble, with the radio on I can barely hear it. They just chopped of the old muffler and tailpipe in one piece and put a 90 bend that exits in front of the tire and put a wide rectagle tip like a supertruck. Looks awesome and sound even better. When I go to sell it I still have the complete stock system, one weld and it's back on.
