tires and rims
tires and rims
just wondering what kind of tries people are running on their trucks. I am in the market and not sure what I really want and need some ideas.
lift kit?
leveling kit?
rims: maker and size?
tires: maker and size?
thank you
pics would be very nice as well
jay
ps this is a place to show off your trucks and wheels
lift kit?
leveling kit?
thank you
jay
Heres an idea for Ya
Hey OMC check out my gallery for the Centerline Stingray III 20s I just put on today. I am not into all the real fancy wheels out these days and I think these are nice and simple but cool at the same time. Just be prepared to wait for them.Centerline is behind on their production and I had to special order these and wait for them for 6 weeks!!
Re: Heres an idea for Ya
Those look great!
I'd say they were worth the wait.
Many folks make rims for the 04 F-150. I have just spent a month researching what would fit and look good. I am an old fart and did not want something too Bling Bling. The thing to keep in mind is off-set. Most places want to sell you a +30 or a +35 offset. This is too aggressive IMO as it will stick out too much from the fender. The stock off-set is +44 ( the higher the number, the closer in the rim will be to the center of the car.) I went with 20" TPX Ego's which are made by Kaotic which is a sub brand of MHT Wheels. They are +45mm positive offset, I installed 275/55/20 Goodyear LS's. Does not stick out one bit! Just the "look" I was looking for. The 04 F-150 uses a 6x135MM lug pattern.
Here are some rims I want for my truck. The only problem is I don't know who manufactures them.
Originally posted by Tough SCrew
I have 25,000 on my 305's with stock wheels. I have rotated them regularly. Nevertheless, they are wearing on the inside. I check the alignment and Ford said it was withi specs.
Any suggestions.
Any suggestions.
The problem here Tough SCrew, is very likely the result of incorrect fitment. In mounting those 305/60R18 Proxes tires, you simply have shoehorned too wide a tire for the 7.5" wide OEM wheels. If you look at the Toyo fitment chart, you will note Toyo recommends a minimum of an 8.5" wide wheel for proper fit. My suggestion, FWIW, is to either buy wider aftermarket wheels, or go back to the place that sold you the tires (hope it was local to you) and tell them they sold you too wide a tire, and ask them to replace the rubber with correctly fitted tires for your OEM wheels. Unfortunately, the Toyo Proxes fitment chart also reveals they do not currently offer anything wider than a 255mm 18" tire -- that is speced to fit correctly -- as even their 285s require an 8.0" wheel.
OMC try running a few searches in this forum, as this topic has been a popular one. The 'reference thread' on the subject can be found here.
