BFGoodrich LT325/55r22would it fit with Daystar lift??
Old Mar 18, 2004 | 06:08 PM
deepblue's Avatar
I am about to order these tires but i am not sure if they would fit with 22'' rims although i already have installed daystar2.5 lift spacers.It' s overall diameter is 36.1.What about the speedometer and gear ratio ??should i recaliber?
Old Mar 20, 2004 | 08:21 PM
Mr_Wizard's Avatar
Deep Blue
Four wheeler magazing just did a section in their march 2004 issue about new lifts for the F150 with the size tires that will fit with what backspacing. If you cant find it I will be happy to fax you the pages if you give me your fax number. I could not find the link on their website.
Old Mar 23, 2004 | 08:39 PM
deepblue's Avatar
I just checked four wheeler's web site but they do not give a link to march issue and although i am thankful to you for your kindness i can not ask more you to fax me cause i live overseas(Turkiye) but if you can e mail i would be very happy cause i really still am not surewhat to do these are really great tires.What i understand from the post about wheels is overall diameter about 35'' or 36 '' is not a problem withdaystar 2.5 '' lift kit as long as the rims width stay between 7.5-8.5 .Backspacing, offset and (huble bore????) seems other issues.I think i will go for more search until i order cause these sets are almost close to 10 grand with spinners included.Thank you anyways
Old Mar 24, 2004 | 10:32 AM
Mr_Wizard's Avatar
Deep Blue
This is the Daystar section of the article:
Daystar 2.5 inch F150 leveler:
Rated lift: 2 inches
Maximum tire size: 33-inch (18x8 whell, 5-inch backspace) 35-inch
Trimming required: None with 33-inch tires. Likely with certain 35-inch tires.
notes: Daystar's 2-inch Comfort Ride kit consists of a pair of Durathane polyurethane spacers-one per side. The 2-inch lift levels the truck and allows tires up to 35 inches to be fitted without rubbing. Daystar specificall recommends a 33/12.5R-18 tire with the wheel noted above as having very good results.
I hope this helps.
Old Mar 24, 2004 | 10:46 AM
deepblue's Avatar
Thanks wizard that is more helpfull so i guess i have to go with 20 '' rims if i insist on gettig those tires.Maybe a bazo b26 20x9 with spinner it allows 35 in offset i guess it will fit with little trimming by the way what the hell is hub bore???thanks
Old Mar 24, 2004 | 10:56 AM
Mr_Wizard's Avatar
deep blue
Hub bore is the size of the hole in the wheel for the hub. If you truck is a 4x4 I would make sure that the hub bore is large enough for the 4 wheel drive front hubs. Hub bore is the reason a lot of wheels designed for 2 wheel drive trucks and cars will not work on 4x4's
